My PC has 2Gb of RAM, processor PIV 3GHz and 500Gb HDD. Before I used win7 64bit, I didn't have problems like that even if I changed my system but now it happens!! Can you help me!
Hello download the right drivers here:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+4+Series+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DG41RQ
Or install a better graphic card, in the pci-e slot on the mainboard for better performance.
The onboard graphic, is useing the physical ram on the mainboard to operate.
Support for up to 8 GB of system memory.
Support for DDR2 800 or DDR2 667 MHz DIMMs
Good luck
thank you!! but I have a question, Which system do you suggest me for my PC:win7 64/32bit or Xp?
I suggest windows 7, 32 or 64 bit because the support for windows xp is phased out next year in april.This means that no updates are available from microsoft.
thanks!!!
SOURCE: mother board problem
sounds like video card driver issue...ensure driver is correct by looking at video card in device manager. Also ensure that system interrupts are being allocated properly.
SOURCE: When I am trying to load OS XP it is not working, but the system is running well with Win98
i think the hard disk might have got crashed or the cd from which your installing may consists some error (or it is unreadable ) ...
just try with other cd ....
or you might have installed some upgraded version of windows than the XP just for example :vista or media center etc .....
or you might be trying to install the XP in the drive which consist of the upgraded version of windows than the XP ....
just check these things and reply me ...
and tell me the what exactly error message you are getting while you go to install the XP ...
any doubts you can reply me
i am always here to assist you..
thank you
bye ..
rate my solution
SOURCE: New Graphics card needed
NVIDIA FX series are very good graphics cards and will run OK on your system
SOURCE: Graphic Problem
This might be an issue with not having full rights within the BIOS, you could try to enter the BIOS and press F8 this sometimes reveals 'hidden' features.
SOURCE: I Have a PC with
The best card you is going to be the PCI card. You have 2 ea. PCI slots and 1ea. PCI x 1 slot. Dedpending on what you want to do with the card, there are quite a few to choose from. You will have to pay attention to the power requirements of the card. The best one I looked at, my opinion, is this one:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161353
It does require a 400w power supply, possible upgrade for you, but, has DirectX 11. 512 MB memory, I gig would be better, HDMI and DVI outputs. I like the Radeon HD cards also because they have a sound chip in them also so, you could use ATI's DVI to HDMI adaptor as well for a second monitor. This is the adaptor:
http://www.txcesssurplus.com/servlet/Categories
The 6141054300G. There are others to look at but, this is a good all around card for the money and your system.
Good luck,
Dave
thanks!!!!
