Possible that the INLET valve is also making noise due to faulty coil, check , confirm by disconnecting the valve. It is so common that the washing machine can make
terrible noise in many ways and is a common fault. In all occasions it is
important that your observation is most important and so is vital to the
identification /rectification and solution. If you have noticed that machine is
vibrating when it is running then the motor /drum suspension has to be
inspected. Since these fittings are located on the underside of the machine it
is important that you look for the noise with a good inspection lamp. Manually
turn the motor and drum and listen for the noise, if so the motor bearings, the
drum agitator shaft and fittings must be checked. Also the suspensions which
include the shock absorbers and springs, the body clamps must be checked to be
in correct alignment and not changed in position. Tightening of the
mounting is also very important. Finally
in most cases a drop of OIL or smear of grease on the moving parts cane solve
most issues. Check this link : http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For
replacement of bearings check for tips on this visual link:
http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
SOURCE: Washer agitates, but makes horrible grinding noise. Spins okay.
thanks for posting problem solve :0)
SOURCE: Loud clicking noise - wont agitate or spin
I had the same clicking noise. Turned out to be the coupling between the motor and transmission. A $15 plus 1 hour labor fix
SOURCE: loud noise while agitating in wash cycle
If you begin dissassembly from the tub down, you wil come to the transmission with the spindle sticking out of it. If you undo the bendable tabs all around the transmission it comes apart in two halves. Careful, its full of oil. The spindle has a plastic gear bolted to the bottom of it. It meshes with other gears in the tranny. It has sheered teath and is making the noise.
SOURCE: Sears Stock# 28803 / Model# 110.28803890 / Kenmore 80 Series
this sounds like the direct drive coupling between the motor and transmission. very common problem and not very expensive. look under the machine and and between the motor and transmission you will see a round rubber coupling and 2 plastic pieces one on either side; they all connect together to mate the motor and trans without a belt.
SOURCE: GE washer (wjsr4160gww) makes loud noise during spin cycle
Remove the front panel and you will see two metal guides attached to the front of the frame. One of them will probably be bent and the transmission assembly will have jumped over one or the other of the guides. You need to manually pull it back to center then straighten the bent guide. May have been caused by load being out of balance or machine not properly leveled. Good luck.
