Hi! I bought an Iomega hard drive LPHD-UPC 3 years ago. I was using it without problems but I only could use the original dual cable that came with the device. If I try to use an USB cable from other hard drive my Iomega doesn't appear on the screen. It just turn the light on for a few minutes and then turn off. I've recently moved to Australia and I have lost the original cable: What cable should I buy now? I have try in several stores and the device doesn't work with any USB cable.
Use a USB 3 cable it will provide more usb throughput
USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/
SOURCE: Iomega large external hard drive doesn't show up
Well this is a tough one. I am assumeing that you have done all the normal things.
Most external hard drives are just a standard internal hard drive with a case and a IDE/SATA to USB adapter built in. When you plug in the drive and it powers up listen to the drive if you hear a clunk. Not a the happy ticking of a normal drive but a bad clunk. This can mean that the controller on the hard drive itself is bad.
If everything sounds happy then I would try replacing your power adapter. I know that the blue light goes on but most of that runs off the 5 volt leg of the power supply (I have has some hardware manufacturers actually pull the power light voltage from the USB port Grrr) most of the Large sized external hard drives use a 12 volt adapter and it can have no problem with the step down to 5 volt it may have a problem with the 12v.The 12v is what it uses to spin the drive. Unless you have one of those little drives. They use a laptop hard drive that works of a lower voltage. Most of the time you can get an adapter from Radio Shack. Be sure to bring the old one so they can get the Volts, amps, poleartity and the type of connector. It is worth a try and keep the reciept. If it is just bad I am sorry but the only way to get the data off is to break into the unit and pull the hard drive out. Then use another USB to IDE/SATA adapter to pull the data off.
Hope this helps a little.
SOURCE: Hi, i have an iomega 500 gb external drive, used
If the power LED is on, it points to a problem with either the disk itself or the housing circuit board. I would open the case up to see what sort of hard drive it is (IDE or SATA) and then get as cheap hard drive housing from Maplin or similar to put the disk into.
SOURCE: Problem with Iomega Portable Hard Drive
get error message from new installed portable hard drive. Access denied. Using windows XP
SOURCE: iMac not recognizing external hard drive
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external ,
go to Start-Control Panel-Administrative Tools-Computer Management-Disk
Management , and see if your external drive is listed here with your
local drives. If it is listed , right click on the drive and change the
drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your
computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your
computer case or another external case.If the drive works , the problem
is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
The
latter is the easiest to diagnose , does your external light up at all
when you plug in the power? If not , then this is probably your problem.
On the bottom of the adapter is a label which you will be able to use
to have a new adapter made at your local electronics shop and this will
cost about $30 max. They will also be able to test the adapter with a
clamp meter to see if this is really the problem and this should be
free.
The second component you want to test is the USB cable. If
you have a printer , swop out the cables and see if your printer
functions normally. Most externals use the same connector so you should
be able to test it in this manner. If the cable works go on to the last
step. If the cable is defective , replace it with a new one which you
can find for about $10 at most electronics and chain stores.
The
last component to test is the circuit board. This is a bit of a grey
zone as you probably won't be able to spot the blown component unless it
failed really badly. With the casing already opened , locate the
external's circuit board and check to see if you have any blackened
components or fluids leaking from some components. If all the other
components of the external worked perfectly , then this is the faulty
part. It is not really economical to replace the circuit as most of the
time it is out of production by the time you need to replace it and it
still costs a lot even if it is available so if your drive is working
perfectly when connected via sata or IDE on your computer , the best is
to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
SOURCE: How do I delete folders
This can happen when you place a drive in multiple computers with windows. Also this can happen if the system used the drive to extract system folders.
right clickt he items and then click security. click advanced and you can go to the owner tab. under that there is a way to take ownership for the selected items and all subitems.
Testimonial: "many thanks"
THANKS!
