Question about Kaz Humidifiers
Mine is model V3100 and has started leaking water out the back
It's been working fine but now twice, there's water on my table and all over the floor. Must have been leaking all the time I was napping; a couple hours. It just started doing this. What could the problem be? I have it in my living room and it's put out enough humidity that my nose is dry in our winter weather.
Posted by CL Vielmo on
5 Related Answers
Anonymous
  • 944 Answers
SOURCE: Hunidifier doesn't add enough moisture to air
here is the link to the manual for the w7 - they suggest a replacement wick filter would solve the problem due to bacteria or mineral build up - i would expect this to solve your problem as the only way these wicks can not soak up the water to the top is if they are clogged or the tank is empty. try the cleaning routine on page 9 first - might be enough but the wicks probably will need replacing soon anyway. http://www.bionaire.com/manuals/W7_English.pdf Hope this helps :)
Posted on Mar 10, 2007
Soulvisitor
Soulvisitor
  • 1113 Answers
SOURCE: Fan is running but humidity is not changing
Q: My unit has been running for several hours. I hear the fan spinning, but I do not notice the water level in the tank decreasing.
A:
First, check the filter to ensure it is wet. If the pad appears dry, remove it from the Base and gently rinse under cool water. Reposition wet filter in the Base. You may also want to note the current moisture level in your home. If the humidity level is over 60% the unit will not put out much moisture
as your air is already saturated.
UV bulb and filter are user replacement items
see manual from my other post
Owners manual LINK
Comment by Soulvisitor, posted on Jan 20, 2008 You should notice moisture on the widows in the room after unit has run for awile, this unit carries a 3 year warranty. More info coming...
Comment by Soulvisitor, posted on Jan 20, 2008 see this
4b54ac1.jpg Comment by Soulvisitor, posted on Jan 20, 2008 If water level in tank is dropping and fan runs then I'd say it is working.
OK?
Comment by Soulvisitor, posted on Jan 20, 2008 Q: I hear the fan turning, but I don’t see any mist. Is my humidifier operating properly?
A:
Dry air is pulled through the system and a fan disperses invisible, moisture balanced air. There is no
“mist” emitted. When operating normally you will feel only cool air coming from the unit. Monitor the
water level in your Tank/ Base. If you notice a decrease in the Water Tank over 24 hours then the unit
is operating normally.
Posted on Jan 20, 2008
Anonymous
SOURCE: How do I know my aprilair 760 humidifier is working?
A simple check you can perform on your aprilaire 760 is the following:
1) locate the two brown wires coming out of the 760 (these wires will be wired to tell the 760 to turn on when the hvac bower is on and the humidistat is calling for moisture).
2) temprarily disconnect the two brown wires from the external wiring and then short the wires together. All you're doing here is bypassing the your thermostat and bower-on indicator.
With the 70 unit plugged in to the wall outlet and the two brown wires connected together, both the fan and the solenoid valve (water inlet valve) should both be activated.
Posted on Dec 29, 2009
Anonymous
SOURCE: Air-o-Swiss room humidifier (model 7142) No mist flows
It is intersting that several folks seem to be having this problem. In early December 2009 I noticed that the replacement AOS demineralization granules were wet when I opened the sealed metal envelope. I opened a couple of others and they were the same way. After a couple of weeks after replacement, the unit started puffing steam before it stopped altogether. My husband opened the cartridge and said all the crystals were clumped to one side. I emptied out the cartridge and ran it for a few days (about 4) without any crystals until it stopped generating mist altogether. Air still flows and the heater works. But it appears that the ultrasonic disc in the bottom of the unit quit. Not sure if this was all coincidental... Especially when seeing several other people with the same problems over the last couple of months.
Tonight the AOS customer service/tech support said I shouldn't run the unit without the crystals but they appeared to be concerned about the white dust.
Anyway, the AOS U7142 has a three year warranty. If you have a receipt call customer service at 1-800-336-0326 immediately. If it is after three years they said they would charge $60 to fix it.
Posted on Jan 05, 2010
Anonymous
SOURCE: Humidifier Leaking over floor, not retaining water, excess bubles
My humidifier is leaking. I is a Vicks V3900 Germ Free Cool Mist Humidifier. How do I solve this problem
Posted on Feb 10, 2010
Making gurgling sounds and spitting water. Do i just need to send it back, it's only a few months old
Before I returned it I would clean it thourghly and refill with clean water and about 1/4 teaspoon of table salt. Run it thru a full cycle and see if that helps. You can also rinse it out and refill with a 1/2 cup of vinagar and run again.This shoul help loosen and clean any mineral deposits. Hope this helps. Thank you.
May 20, 2011 | Vicks V3100 1.2 Gallon Humidifier
We havehad this humidifier for 3 months ans have has problems with a foul odor coming from it. We have replaced the filter 3 times! Is this normal? The cost to keep replacing the filter is ridiculous. Any...
I have the same poblem with mine. I'm telling you it was the brand new filter...after about a day the odor would start. I washed the filter out with white vinegar, then a drop or two of Dawn in hot water, then rinsed in cool water. Worked fine so far. It's been about a week. good luck
Jan 14, 2011 | Vicks V3100 1.2 Gallon Humidifier
I have a Vicks V3100 and dont know how to put it together or if I even have a filter. I do not know what the filter looks like
There is a Wicking Filter that is also the same media that creates the humidity. This filter looks like rolled up paper media(like for a swamp cooler). This filter installs at the back of the unit with the water resevoir removed. The water then is absorbed by this media and as the air passes through it humidity is released into the air. The Wicking Filter will need to be replaced when the performance of the unit decreases and the material becomes hard from mineral deposits. There is also a Protec Cleaning Cartridge that looks like a small plastic ball with a stem on it. Inside this cartridge are softening agents that remove hard minerals and extend the life of the Wicking Filter. The Cleaning Cartridge is just simply placed inside the water resevoir. To prolong the life of the Wicking Filter and unit make sure to use clean and cool water. Distilled water will work the best if available. The harder the water you use the more the unit will need cleaning due to hard water. When the unit becomes clogged with diposits you will need to run a solution of vinegar and water through the unit to clean it. If you use distilled or filtered water(reverse osmosis) then the unit will rarely need cleaning.
May 14, 2010 | Vicks V3100 1.2 Gallon Humidifier
Water is leaking through the tray & out of the bottom. How can I fix this?
Your tank should have a little o-ring seal that can be easily replaced. It's possible that is came loose when you removed the tank.
Mar 12, 2010 | Vicks V3100 1.2 Gallon Humidifier
Feb 09, 2010 | Vicks Humidifiers
The spring fell out of the cap and now water leaks out. Can you get a replacement tank cap?
go to kaz.com and search using your model # (found on the bottom of the unit usually). i had to do this a few months ago.
Oct 18, 2009 | Vicks V3100 1.2 Gallon Humidifier
Just bought a Vick's V3100 Humidifier. When I turn it on the fan starts up but then sounds like it bogs down and stops.
the fan is not working properly it is defected,return item back to store or factory,if can you will have to repair but cost more then item.if my info was of help to you please leave a comment,vote,note.thankyou
Sep 09, 2009 | Vicks V3100 1.2 Gallon Humidifier
Vicks V3100 1.2 Gallon Humidifier leaking
Check if the cap has a gasket or o-ring and is not worn. There are two designs for this model. The older model has the fill cap and valve together. The new design the fill cap and valve are at different locations. The new design has no hole in the bottom of the unit.
You can fixed the problem using a 1-1/2 inch washer for brass tubular found in the plumbing isles in HD or L. The rubber washer is 1 or 2 mm smaller then the grooves in the fill/valve cap. You can stretch the washer and it will fit perfectly in the grooves. When putting the fill/valve cap back with the washer, it will be tighter then before. Firmly turn and you should not have any leaks and make sure unit is level. You can plug the hole because the new design does not have a hole in the bottom of the unit.
Nov 28, 2008 | Vicks V3100 1.2 Gallon Humidifier
No steam comes out
I just took mine apart and cleaned the scale off the heating elements. Filled to the level with hot water and it was steaming good in about 2 mins.
Mar 01, 2008 | Vicks V150SG 1 Gallon Humidifier
Filling humidifier
On the Vicks v-3100 the water tank should lift off of the unit. Flip it over and there is a lid. Open the lid and fill the tank. Once you've filled it back up, put the lid back on. Flip the tank over to make sure there are no leaks, then put it back on the humidifier.
Note: It's very important to check to make sure the tank isn't leaking before you put it back on the humidifier, if it is, it will flood the reservoir, in turn causing water to leak out of the bottom of the humidifier (which is one of the major complaints about the 3100).
Sep 11, 2007 | Vicks V3100 1.2 Gallon Humidifier
Humidifiers Logo
361 people viewed this question
Top Kaz Humidifiers Experts
ray gallant
Tom Chichester
Are you a Kaz Humidifier Expert? Answer questions, earn points and help others
