I use a home wireless network with my company laptop. I have internet access, but am unable to connect to the company VPN server. Our company uses Cisco VPN Client 5.0.07.0290. It attempts to connect, but fails and times out. I have also connected my laptop directly to the modem, via Ethernet cable, and still could not make the connection.
SOURCE: CANT GET VPN CONNECTION
the vpn connection from your home to work or the vpn connection from anywhere else to your home by vpn.
here you find a forum with the same problem:
http://broadband.motorola.com/consumers/support/faqs/surfboard_faq.asp#cant_login_vpn
SOURCE: I get connected to my work VPN, but i can't sea any servers.
Because when you want to browse free it will happen, so better check with he hotel/fastfood or airport IT admin, he would have blocked it.
Good Luck
Johnson
SOURCE: Moto Surfboard SBG900 and VPN Client = SLOW
Please see the specicification, also check with you company
IT Admin, to release it to the Max speed or to check the
net work cable, may be too long, also Test the cable with a Data Test meter and conform the data quality. Or change the port from main router.
Otherwise change the whole networking router.
Regards
SOURCE: cable modem + dlink router
Your modem needs to be rebooted in order for your router to pull an IP from the modem. To do this, look for a little hole in the back of your modem and use a pen to push the button. Wait for the reboot to finish and then try again in about 20 seconds.
SOURCE: Unable to set up wireless router
Shut down your computer, unplug the cable modem and the switch. Connect all three - computer to switch, switch to modem. Make sure that the ethernet cable between the router and the modem is in the router uplink port and that the computer is plugged into one of the four ports that look alike. Wait 30 seconds - plug in the modem. Wait another 30 seconds, plug in the router, wait another 30 seconds and boot the computer. Open a browser and see if you have internet access. If you still don't, then try to check the browser by typing 192.168.1.1 into the address bar of the browser. That should give you the browser sign in screen. The Linksys default is to leave the user name blank and type admin for the password. That should give you access to the router so you can check the settings. If this doesn't work, document carefully what happens and post again with your results and we'll try to go from there.
