How to install Java games on the Samsung L700 without any software or drivers
(I've done this on a pc with Windows XP and don't know how well it would go on any other OS)
In the phone Menu select
'Settings'
Then select
'Phone settings'
Then
'USB settings'
And choose
'Ask on connection'
Plug the Phone in to the PC with the USB cable
On the phone selct
'Media player'
On the PC wait until it detects the phone and select
'Open the device to view files'
Open the folder
'Phone'
You should see the folders: images, Other files, Sounds, Videos
Create a new folder and name it
'Games'
Put any game you want to install in that 'Games' folder
Two things need to made sure of when copying over the games. Firstly make sure you have the *.jar and
*.jad files for each game, if you don't have the *.jad file, you can download a jad creator pretty easily, just type it in Google. Secondly each game has to be in it's own folder, if you just dump all the *.jar and *.jad files directly into the 'Games' folder only the first game installed will work (Poorly too).
Unplug the phone
Now on the phone dial the code:
*#6984125*#
Select 'Internals' (Number 4)
It will ask for a master key it is:
*#9072641*#
Select 'Storage settings' (Number 7)
Update Java DB (Number 2)
Now on the phone enter the code:
*#6984125*#
*#9072641*#
Turn the phone off
Turn it back on
*#6984125*#
*#9072641*#
The games should now be installed with no problems, I know it's bit repetitive but this has worked the best for me.
(Note: if you delete a game on your phone and then want to reinstall it later you will have to give that game a different folder name before you put it in the created Games folder. It won't allow that folder name again even though you've deleted it)
SOURCE: how to install .jar files in samsung sgh d780
hey samsung mobiles have a typical problem with this java appliacationa installion. we need .jad file with .jar file both are to place din memory card.open the memory card and open the .jad file then it gives the option to instal.
ENJOY.................
SOURCE: how to read pdf files
I can't read pdf files in my samsung mobile B5722.
kindly can i get any suggestions how to read pdf files in my mobiles.
SOURCE: i cant read hindi &
i want to download a marathi fonts on my c3010-s samsung mobile is ti possiblee
SOURCE: USER MANUAL FOR A SAMSUNG GALAXY S2
http://www.manualusersguide.com/samsung-galaxy-s2-user-guide-manual-pdf-download.html
Hello here is the link where you can download the user manual for your phone. I have downloaded it for you so you dont have to do it but for some reason i cant attached it in here. So instead i give you the link. It is easy jsut go in this site and at the very bottom you will see download samsung user manual pdf. .just click it and you will be downloading the pdf file in no time..
Hope this can help you..have a nice day..
1 - Switch ON your Samsung Galaxy S2 with a NOT ACCEPTED SIM Card.
2 - Compose : #7465625*638*CODE# (or *#7465625*638*CODE#).
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung Galaxy S2 is locked to.
CODE: Its the unique Unlock Code for your Samsung Galaxy S2.
