Panasonic NV-GS15 Mini DV Digital Camcorder Logo
Aftab Shaikh Posted on Jul 21, 2007
Tape rack stayed open
When I ejected the tape and took out the tape, the tape rack stayed open and went down. Now I cannot close the cover. What can be done?
  • Juozas Butvilauskas
    Juozas Butvilauskas Dec 01, 2008
    on my NV-GS15 tape rack stayed open and went down. I tryed to press down a little mechanical arm what you said, but it not pressing enough and the rack is not works properly. Please help!
  • Anonymous May 14, 2009
    you have to mess with the mechanism quite a bit. It helps to be a Jedi :)
robert van d
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 22, 2007
robert van d
Contributor
Level 1:
Answers
Questions
0
Helped
329
Points
I just experienced the same problem, but it took me 10 minutes to get it working again. When you look inside the tape rack, you see on the left side in the middle a little mechanical arm which you can press down for about 1cm when you release it again the rack opens completely Good luck Robert
Anonymous
Level 1:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Jun 10, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
11
Questions
0
Helped
13670
Points
18
Make sure the hand strap is loose and allows the door to open completely - mine seemed like it was open all the way and it wasn't - loosened the strap and opened it a fraction of a milimeter more and the mechanism then functioned propertly again.
How can I get my tape to eject?Sharp VC-A560. Played my taped, rewound, but tape would not eject. Tried to play again and it would not play.What can I do?
Unplug from wall outlet - find the wheel that ejects the tape when you slowly turn it. It's usually on the right side when the cover is open. Avoid touching any metal parts.
Cannot get tape to eject
It could be a couple of different issues. These things could help.
(1) Power OFF the camera, remove battery then replace the battery, power up the cam and try to eject tape again. Nothing? try...
(2) Gently press inward on the tape cover with both thumbs a few times. Then, while pressing gently inward with one hand, press the release/eject-tape function until you hear a click or release sound. Then, if it doesn't open automatically, gently "help" open the hatch.
If it remains stuck, after follwing these steps a few times it would be my guess that perhaps the camera has been dropped in a way that jammed the mechanism controlling the eject function.
TIPS that may prevent having eject problems: When loading tape, be sure to insert the tape correctly and slowly, makeing sure the tape is placed properly. Gently press on the specific location indicated to close the tape holder, and wait for the tape to "seat" properly before closing any other part of the tape cover or hatch mechanism. Taking a few extra seconds when loading the tape can save extended frustration later.
2helpful
Canon es55 video camera. Everytime I put a tape in, it ejects it. If I take the tape out, and close the door,it will will automatically close and stay closed
1helpful
2answers
I have a panasonic mini dv video recorder. After
close the tape compartment take the batery of press the power button on and holding the power press put the batery back and wait let me know
1helpful
Panasonic VHS Won't eject Tape
unplug then remove the top cover press down on the cassette release and remove the tape then rewind the part of the tape still sticking out by hand push in the button on the side of the cassette to open the cassette cover
Disc Tray wont stay shut
A lot of people have this problem. Before you post, look around.
Anyway, I was able to call xbox 360 customer support. We did the troubleshooting but it still would not work, so they took my xbox 360 in for repairs. I would not try to fix it on your own because it might negate the warranty.
Xbox Support: 1-800-4MY-XBOX
1helpful
Gs36 tape door doesnt open
In case anybody read this....     I have a GS-36 that would not eject the tape. I removed all the screws from the bottom and pulled the bottom plate off. Then I fidgeted with the mechanism near the eject button towards the front of the camera.  In my case it had just become stuck and needed to be gently pried open.    Tested it a bunch of times with tape - seems to be o.k.!
33helpful
5answers
"Re-attach the power source" but tape is stuck, door open
I had the same problem. First, depress the reset button, located on the camera body (where the LCD screen closes over it). It is hard to see at first. It is important that the camera be set to the OFF position. When the camera is whirring after the reset, then hit the EJECT button so the tape comes out. Take the tape out and insert it back. That's it. My camcorder worked fine and let me record or plaback once I followed those steps.
Vic
1helpful
2answers
A similar thing happened to me - I took it to panasonic service centre to fix and unbelievably the problem was that the HAND STRAP was quite tight (I have small hands and set it snug) and prevented the door from openeing just another milimetre more, and thus caused the carriage to 'jam'. Loosening the hand strap and opening the door allowed the tape carriage to move properly again. This was a great relief (although I still had to replace the carriage mechanism a few months later.....due to reset button message)
2answers
Eject stuck open
Yeah i have a PV-GS70 and the same thing happened to me. The casing is still open as we speak. Im taking it to a camera shop tomorrow
Top Panasonic Video Cameras Experts
Marvin
Marvin
NOEL
NOEL
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
