2002 Chevrolet Tracker Logo
Posted on Jan 21, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2002 tracker,keeps blowing 15 amp fuse that runs heatr fan and lets car shift out of park
Stephen
Level 3:
Top Expert:
  • Chevrolet Master 21,873 Answers
  • Posted on Jan 22, 2013
 Stephen
Chevrolet Master
Level 3:
Top Expert:
Answers
21873
Questions
0
Helped
6207721
Points
67230
I looked at the wiring diagrams and those two circuits should be on two different fuses.
The shift lock solenoid is powered by the 10amp turn signal fuse and the 15amp stop light fuse. If the fuse blows when you put it in park, I would say the shift lock solenoid is the problem and the stop light fuse is the one that is blowing.
The heater fan and relay are powered by a 60amp fuse and a 15amp fuse but not the stop light fuse.
Its possible there is a short some where that has connected these two circuits.
You could disconnect the shift lock solenoid to see if the fuse still blows.
5 Related Answers
autodr
autodr
  • 260 Answers
  • Posted on Nov 15, 2008
SOURCE: 2002 Chevy 1500 has problems shifting out of park
ck to make sure all brake lites are working. (could be faulty brake lite switch). if so, do you hear a click in column when applying brake to pull out of park? could be the start of bad shift interlock solenoid.
motor1258
Mike Butler
  • 6674 Answers
  • Posted on Jan 31, 2009
SOURCE: 2002 Dodge Neon 20 amp FP/ASD fuse #21 keeps blowing
It appears that it is part of the fuel pump circuit, so I would concentrate on wiring harness & connector at fuel pump, clean it real good, and apply dielectric grease to the connection, as well as the fuel pump relay, connector & harness.
MikeRenee
  • 69 Answers
  • Posted on Mar 29, 2009
SOURCE: How to remove electric fan in a 1999 Chevy Cavalier
Make sure you don't have delco loc 2 or theftloc audio system before disconnecting the battery. You should be able to do this by contacting your local dealer and they run the vin and tell you.
disconnect battery
unplug connector from fan motor
remove bolts holding fan shroud to radiator
pull assembly up to dislodge the holding tabs then guide the assembly out from the car
make sure all wiring is unplugged
carefull not to contact the radiator fins they are sharp
remove the fan retaining bolt from the assembly
install is reverse
Hope this helps
airjoc
Rob Sinbad
  • 709 Answers
  • Posted on Jul 12, 2009
SOURCE: I have a 1998 chevy blazer (s-10) 4.3L 4x4 it
check transfer case electrical switch, sometime if it bad it will also blow the fuse. don't recommend you put any higher fuse than recommend, If the fuse blow there is a short some where and by putting higher amp fuse you might short or burn something else beside the fuse. if that check out than check your transfer case motor, might lock up and not allowing the motor to turn instead it short the fuse. don't drive the car, just leave it in park, put correct fuse amp back in and unplug transfer case electric switch and turn the key on (dont start the car) and see if the fuse blow; if not plug it back in and see if it blow the fuse. if that is not the case, unplug transfer case wire, and do the same and see if it blow the fuse.
Mike
  • 4383 Answers
  • Posted on Jun 13, 2010
SOURCE: keeps blowing 30 amp fuse to the fan blower.
Well, something downstream may be damaged and grounded, or the motor itself has deteriorated, causing excessive draw.
3answers
WERE IS THE FUSABLE LINK IN 1993 COROLLA?
I found this useful diagram at troubleshoot vehicle.com. It answers your question. Fuse box is located below steering column.
Driver Side Fuse Panel
(1993-1996 Toyota Corolla) December 21, 2013 Updated: December 21, 2013 Written by: Abraham Torres-Arredondo driver-side-fuse-box.gifIn the table below you'll find the fuse location and description of the fuses of the driver side under-dash fuse box on 1.6L and 1.8L 1993-1996 Toyota Corolla.
The fuse box is located on the driver side of the dash, below the steering column.
1993-1996 Toyota Corolla Driver Side Fuse Box Fuse Fuse Name Amps 1 Cigarette Lighter, Digital Clock, A/C System, A/T Shift Lock, Alarm, SRS Airbags 20 2 Tail, Parking & License Lights, Instrument Panel and Daytime Running Lights 15 3 Fuel Injection, Cooling Fans, Battery Discharge Light 10 4 Cruise Control System, Daytime Running Lights 10 5 Fuel Injection System 7.5 6 Stop Lights, Cruise Control, Shift Lock System, Anti-Lock Brake (ABS) System 15 7 Turn Signals, Emergency Flashers 10 8 Starting System, Anti-Lock Brake (ABS) System, Shift Lock System 15 9 Gauges, Reminder Lights, Back-up Lights, A/C System, Daytime Running Lights 10 10 Front and Rear Wiper/Washer System 20 driver-side-fuse-box.gif
Tail lights wont come on keeps blowing fuse blows 10 amp 15 amp and even 5 amp fuses
put a 12 volt light bulb in place of the fuse. It will stay lit until you find the short circuit. Check tail and park light & side marker bulbs first.
How about if you just turn parking lights on, not headligths
2answers
Door ajar light is on when all doors are shut, fuel guage reads empty and dummy light is on saying get gas, all lights in the rear do not work i.e. brake, running, reverse, blinker, hazards. 15 amp fuse...
your stop light switch is broken and shorting out hence it will not start in park ,or you have a fitted the wrong bulb in one of the back lights like a twin connector bulb in place of a single or visa versa ,which is blowing the stop light fuse ,with this fuse blown your stop light switch isnt working hence you cannot get it out of park .also flasher could be using the same fuse as the stop lights .side lights should work but if wiring is being shorted out then anything is possible
I have a 2002 Ford F150. Fuse 15 (5 Amp) keeps blowing.
replace nuetral safty switch for gear shifter and check window relays
I have a 2001 F-150, 5.4 litre, 4x4 truck. Fuse
first find out the right fuse rating if correct ///operate one electric switch at a time and look for fuse blown ///that part is involved ///
1992 Geo Tracker keeps blowing fuse for ignition coi/meter(15 amp)-Checked wiring harness and components and no problems found-Will usually run for 1 to 2 weeks then blow fuse several times-then will run...
could be the main computer - but last time a saw - they where over a $1000.00 dollars. suggest finding some one to install a matching amperage circuit breaker in place of fuse. it will trip and automatically reset - caution : if problem gets worse, could cause wire melting and fire
9helpful
2answers
I have a 1998 chevy blazer (s-10) 4.3L 4x4 it keeps blowing the #15 (10amp) 4wd fuse, if you put a 10 amp fuse in it will blow the minute you turn it on ,then we put a 15 amp in it seems to do it when you...
2helpful
3answers
Brake switch fuse keeps blowing
replace your brake pressure switch on the master cylinder and that should take care of your problem.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
