SOURCE: Can't clean Ionic Pro CA-500 inside?
This unit is a pain in the @$$ to disassemble but it CAN be done. The way I always look at it: Someone ASSEMBLED it.
Remove the four screws on the bottom stand followed by two screws on the bottom side of the unit. Then remove the tiny little screws up each side that hold the grill together (you will need a precision screwdriver).
Carefully pull apart- don't force it.
One half comes off (clean that half) in bathtub. The other half does not come off-vacuum that half out and use q-tips.
When re-assembling, watch for two things: First the wire cleaner (that slides) runs on a track on each half- pull it out a little to best allow for fitting. Second, there are little tabs at the top that fit under the control panel-watch for those.
email me at [email protected] if any problems.
SOURCE: Ionic Pro CA-500B Power On Instant Clean Light
If the plates are clean, there is nothing wrong with them. They are just 3 strips of metal... they don't even connect to each other unless they are in the unit. NO NEED TO REPLACE THEM.
SOURCE: ionic pro turbo
You need to clean all the stainless steel contact points inside the unit, not just the blades. Make sure you unplug the unit before doing this.
