Samsung NV3 Digital Camera Logo
Question about Samsung NV3 Digital Camera
Shutter noise How can I eliminate the shutter noise? I have turned all sounds off but there is still a sound when taking a picture.
Posted by Robert O'Connell on
Anonymous
    Sergeant:
  • 274 Answers
Here's a link to Samsung Customer Support for cameras: http://www.samsungcamerausa.com/support_contact.asp You should be able to get all your questions answered here. Good luck
Posted on Jul 14, 2007
How do you stop the beeping sound when you press the menu biuttons etc e.g. like to view your pictures etc on the SONY Cyber-shot DSC-W350 ? it is really annoying to hear the beeping every time you...
I have a W560, but maybe it's the same on your camera. It was driving me insane as well. On my camera, I went to the menu, under Main Settings there was something called "Beep." It gave the options of "Shutter, High, Low, and Off." If I chose Shutter, then it keeps a shutter-like noise when you take a picture but turns off the annoying beep whenever you push any other button. I assume if you choose Off it will turn off all noises.
Hope that helps!
The viewer is "black". The camera takes pictures, goes through th motion, sound, but the picture is black, no image
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
1helpful
My CAMERA MAKES A CLICKING NOISE WHEN TAKING PICTURES
Go into the Setup menu by selecting the wrench icon. Navigate to Sound Settings (speaker with sound waves if you've set icons). Turn Shutter Sound off.
1helpful
Black screen
2answers
The display does not come on, there is a "busy" sign flashing
Sounds like the problem Canon had to fix for me with my S2 IS which did the same thing. My camera shot blank pics. It turned out to be a stuck shutter. The camera makes all the usual noises, but the shutter is stuck closed.
About camera shutter sound
HI Maddy, You can turn off the shutter sounds in teh settings menu. This will turn off the sound altogether so not ideal but at least a work around.
I go into setup on the camera to turn on the shutter sound how-ever when i switch back to the men u it doesnt show that i have turned it on, and when taking a picture it doesnt work. Is there another...
You Can not have Continuous Shot, Or BBC on if you choose to have a shutter sound. Both must be shut off in order to achieve shutter sound.
W810i
menu,camera,more...scroll down to shutter sound n turn it off
3answers
Error Code
No, it's not an error. What this display indicates, is the availability of the total number of photos you want to take. If the display says, "r06", then you are in JPEG Mode. If it says "r03", then you are either 1) in RAW Mode, or 2) have your Noise Reduction on (see FAQ #2). As you take a few photos in succession, you will notice the indicator drops by how many photos you took.
1helpful
6answers
Nikon D70 - err - won't take picture
Today I was taking photos and the camera quit...the top display says err. The book says release shutter, but I push the shutter and it does nothing but make a little click and the err stays. I took the lens off, and the camera does look like the shutter is open or something.
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
