How much performance octane booster should be added to to a 20 gallon tank and what is the best way to do it for optimal performance.
SOURCE: Treated gas for moisture. Got high octane additive.
Even a small amount of bad gas can cause your problem.
So the first thing you need to do is remove your fuel tank so you can drain all of the old fuel out,then remove the fuel sending unit and fuel pump assembly thats in your fuel tank and clean the filter screen, after that you can reinstall the fuel tank,replace your fuel filter and I would have a fuel injector sevice done.
Unless you are very skilled in automotive repair, leave this one to a pro.
SOURCE: Chrysler 2000 Sebring will not start
remove the air inlet hose to expose the throttle body, open the flap(simulating wide open throttle) spray carb n choke cleaner in to the engine if the engine start u have a fuel problem, like fuel pump or no injector pulse. if the car still doesnot start then u have a ignition problem, cranksensor or cam sensor etc... they should set a code
Testimonial: "Worked like a charm. Many thanks"
SOURCE: I am not getting good
only the mechanic can answer that, he's the one looking at the car. If he diagnosed a bad valve, get it fixed., then see if it made a difference.
SOURCE: 98 Town and Country ran excellent. Ran out of gas.
Start with the simple thing TRY changing out the fuel filter.
SOURCE: Someone sugared my gas tank. i have a chrysler 300
First off it is a myth that sugar will destroy an engine. Sugar will not dissolve in gasoline. Depending on how much sugar was added it could clog the fuel pump sock filter. You have drained the tank, so add 5 gallons of fuel to the tank and start the engine. It will do no harm whatsoever. You may have to change the fuel filter a few times if the sugar clogs it but otherwise no harm will be done.
