My 2005 lincoln navigator is stuck on park it turns on but wont go into gear
SOURCE: 2005 Lincoln Navigator. Message says to Check
Most likely the problem you are experiencing with the park assist is a fault in one of the sensors mounted in the rear bumper. I would not consider it to be a major fix, however there will be a few hours labor involved as the bumper cover needs to be removed to replace the sensors.
SOURCE: 2004 lincoln navigator gear shifter locked
Make sure that you have brake lights. It has a shifter interlock solenoid in the console that is activated when ever the brake lamps are on.
SOURCE: 2002 lincoln navigator shift level is stuck in park
sounds like a dead battey, have you checked it?
SOURCE: my lincoln towncar 1994 is stuck in park unless i
Your brake lights are most likely inop. this is what triggers this.
