Cuisinart BFP-703 SmartPower Duet Food Processor Logo
Matt Flood Posted on Jul 13, 2007
Food processor died
The food processor attachment doesn't work anymore - you can turn the rotating piece at the bottom, but it doesn't turn the piece out the top, and therefore the blade. The blender attachment still works fine, so it's not the motor.
  • divinglead Dec 24, 2007
    Same problem, it seems as though there is a clutch that's worn in the gearbox because it won't produce any torque to cut, but mine will spin loosely when there's no resistance. I'm gonna take it apart and check it out.
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Feb 24, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1544
Points
The plastic "clutch" with the teeth is probably cracked or stripped. you can buy a replacement.
  • Christina Conyers Dec 13, 2010
    Cwlewis...can you tell me where I can get a plastic 'clutch' replacement. Mine cracked too. Thanks :)
1helpful
Our new food processor doesn't fit our old Bosch
There is a separate discussion on this on fixya. The plastic piece should automatically "retract" back into the handle when you attach the processor. Some have removed teh plastic piece and reports it works then, but you should not need to do that.
tip
The Cuisinart 7 cup food processor will not start?
Check out this options Remove the work bowl completely. Turn the machine on and use a pen to depress the dark grey or black button on the base of the Food processor. If the motor doesn't spin, it needs repair. If there is spinning:Make sure the handle of the bowl is facing the front of the food processor. Place the lid tab just to the left of the handle and slide it toward the handle until it won't turn anymore. Remove the pusher sleeve from the lid and reinsert it with the lock facing the front of the food processor. Slide the lock into the locked position. If it still doesn't work, replace the third piece on the work bowl - the one piece that you haven't replaced. It will then work. This will help. good luck.
on Mar 08, 2010 • Food Processors
Flashing Red Light, will not turn on
Something needs to be reinstalled or reset. You may not want to turn it on right now. If that is a warning lamp. Is this the first time used?If so, unplug it and use the blade tool to manually rotate the motor in direction of normal rotation, rotate several times and hands and tool clear, plug it in. Good Luck_Ned_
My food processor is ancient and works like a new one. but broke a piece (small nick) from the bowl. All blades work fine but cheese grater. The only thing I can provide for id number is CFP 9A. This is on...
You should probably not use the thing anymore. The type of plastic they used back then gets very brittle over time, and there's a chance that the bowl could shatter while you're using the processor. There's a chance that if that happens the safety switch will stay engaged and the unprotected blades will keep spinning, right where your hand is. It happened to me.
1helpful
The Blender attachment will not turn, just grinds and smokes.
The motor shaft that spins the teeth that are on the base of the blender may be frozen up for some reason. If you purchased the duet within the last 3 years and have a receipt, call Cuisinart to get it repaired in warranty - even if you don't have a receipt, your serial number may still save you. If you purchased it more than 3 years ago, let me know.
Motor runs but switch won't activate despite new parts
-Tha Mp3 Doctor
22helpful
Cuisinart 7 cup food processor wont' start
Remove the work bowl completely. Turn the machine on and use a pen to depress the dark grey or black button on the base of the food processor. If the motor doesn't spin, it needs repair. If there is spinning:
Make sure the handle of the bowl is facing the front of the food processor. Place the lid tab just to the left of the handle and slide it toward the handle until it won't turn anymore. Remove the pusher sleeve from the lid and reinsert it with the lock facing the front of the food processor. Slide the lock into the locked psoition. If it still doesn't work, replace the third piece on the work bowl - the one piece that you haven't replaced. It will then work.
-Tha Mp3 Doctor
3helpful
Cuisinart Food Processor Custom 14 turned off
Cuisinart Food Processors – Motor Test
First, do a motor test by removing the work bowl completely and using a pen to press in the grey button on top of the base (with the food processor turned on of course), toward the back. If the processor spins, the motor is still good. At that point, I would inspect the work bowl pieces, lid, pusher assembly, etc for cracks/damage. If all appears well, insert ALL the pieces back into place and try again. If even one piece is out of place, the processor will not spin.
If it no longer spins, the motor has a problem.
-Tha Mp3 Doctor
4helpful
My food processor turn on button won't work.
-Tha Mp3 Doctor
The cuisinart food processor doesn't work.
-Tha Mp3 Doctor
Top Cuisinart Food Processors Experts
Marvin
Marvin
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
