Car won't start. Trunk will not release with button from inside car. Key pad will not do anything. When I try to start the car the engine makes no noise but everything inside the car turns on, I'm even able to move the seat
Be sure its all the way in park or try neutral.Its possible that security system does not recognize the key. Is security light flashing or on steady? Shut all doors and windows,trunk,hood, turn off all accessory's,roll down drivers window, turn key off and remove for at least 1 minute, insert key into ignition, try to start leaving key to run position for 20 minutes, turn key to off,wait 15 seconds, try to start again leaving key to run, wait 20 minutes, turn key off,wait 15 seconds, try to start, again leaving key to run, wait 20 minutes, turn key off, wait 15 seconds, try to start. This should relearn key code. It may relearn after 1 learn cycle and start if system is ok. Hope this helps and that the weather is dry and warm for this procedure! This is not always a fix, but works most of the time.
