V-6 5-sp check engine light does not come on runs good when it is running
SOURCE: chrysler 3.3 vin r v6 mini van, starts then dies
Charlie. You have replaced the ECM on your van?.
Kedwin,, Your problem is, the computer on that 3.3 L.
Need to be programed with the VIN nember of your car.
The Antitheft System will disable the injectors due a incorrect VIN, Bucause the body computer is not recieve the correct pasword between 5 seconds after start up.
YOU have 2 options. 1 get a ALOHA Smith. some of they have the computer required to program ECMs.
The other option is: Get a new ECM from the dealer, They will program if ask for that.
NOTE:::::: Other way is . Put the body control module with the computer from the same car.
OK... I hope this work for yours.
If NOT letme know I can look for more information.
Thank you.
SOURCE: 2000 durango 5.2 cold starts, engine stalls or rpm surging
i know this may sound stupid but if your battery is old or a little weak on this vehicle the idle air control solenoid will act speradicley hunting for were it should be and the vehicle will stall.replace battery
SOURCE: 92 dodge 318 truck engine runs til you stop, then stalls when put
Then i think i'd be dumping some soapy water on the intake gaskets checking for leaks. ANd wiggle the **** out of all vacuum hoses. ( you probably did that) And if there aren't any, your cam could be tired. You got a tough one there. Hard to figure with a keyboard.
SOURCE: 2001 Dodge Ram 2500 HO Cummins 6 Speed
The "wait to start" light is your glow plugs. You must have a loose connection to them or something not connecting. They come on almost everytime you start them, hot or cold.
