My younger brothers' truck did the same thing and there was a relay up under the dashboard that would get hot and shut of(kind of a circuit breaker unit) most of the operating systems will flash at you when only battery voltage is available which explains the lights coming on..these newer trucks also have a performance chip in the system that will act up when it gets warm also..replace this and you may be ok..let me know what happens also.. good luck.
SOURCE: anti lock brakes
Brake system warning lights illuminate to alert the driver to various brake system conditions and are usually located on the instument cluster.
Each time the vehicle is started, the ABS control module performs a diagnostic self-check of the ABS system. During this self-check the ABS warning light in the dash panel insert will illuminate for a short period of time . After the self-check has completed the ABS warning light will go out.
If a malfunction is detected within the anti-lock braking system during the diagnostic self-check, the ABS warning light will illuminate and remain ON and ABS will be turned OFF, until the cause of the malfunction is repaired. How ever the conventional braking system will remain fully operational.
The brake warning light will illuminate if the brake fluid level becomes low or if the parking brake is engaged.
Hope that helps...........
SOURCE: Blazer Stalling, Please Help
I am not sure but you might want to check the pressure of the fuel pump.
SOURCE: Car dies while driving, now it won't start sometimes
Could be a fuel pump that is going bad. Some times when fuel pumps go bad they cavitate and pump not just gas but also air. If you get too much air in the line and not enough gas the car won't start. Have a mechanic check your fuel line pressure.
SOURCE: Runs fine going uphill but starts misfireing going
po300 random misfire it needs a tune up..plugs and wires, air and fuel filter........po452 fuel pressure sensor or the fuel level sensor..The fuel pressure sensor is located on top of the fuel pump module.Hope this help...pls rate
I didn't mention that it is a diesel engine and we have had the remote mount PMD kit changed out twice as well as the electrical fuel box. All repairs were done in 2012.
sounds like the autoshutoff relay may be going out this shut down fuel to the injectors ..try changing that out and see if it works..repost please thnx
