Kyocera 7135 Handheld Logo
Posted on Nov 30, 2017
Need to switch Kyocera 7135 from US Cellular to Alltel
My Alltel account is charging me roaming fees because my replacement 7135 was set up for US Cellular, out of the box! They cannot change it at Alltel. Anyone else had this issue and what can I do? I tried a Blackberry and hate it in comparison to the 7135, so really want to keep this new 7135. They are amazing phones.
1 Related Answer
Anonymous
  • 18 Answers
  • Posted on May 26, 2008
SOURCE: my 7135 kyocera is locked to verizon service i need the code to unlock so that i can use the phone with my current service provider,the phone is a gift my sister the previous owner
All you need to do is install palm desktop. This should have been included with the CD in your package. If for some funny reason it is not, go to here.
But don't forget to plug in the USB/Serial cable (whichever you prefer to use), then, select USB or serial after installing palm desktop (just right click the HotSync manager and if your choice isn't selected, go ahead and do so).
Hope this helps!
- 2 Bunny
2answers
Apn settings for safetynet wireless lifeline on my kyocera zte N3192
APN & data settings
  1. From any Home screen, tap Apps.
  2. Tap Settings > More > Cellular networks.
  3. Tap Access Point Names.
  4. If available, tap the T-Mobile US APN.
    • If not available, tap the New APN icon.
    • To reset your APN settings, tap the Menu icon with three dots, then tap Reset to default.
  5. Verify and update the following settings for the Data APN:
    • Name: T-Mobile US
    • APN: fast.t-mobile.com
    • Proxy: <Not set>
    • Port: <Not set>
    • Username: <Not set>
    • Password: <Not set>
    • Server: <Not set>
    • MMSC: http://mms.msg.eng.t-mobile.com/mms/wapenc
    • MMS proxy: <Not set>
    • MMS port: <Not set>
    • MMS protocol: WAP 2.0
    • MCC: 310
    • MNC: 260
    • Authentication type: <Not set>
    • APN type: default,supl,mms
    • APN protocol: IPv6
    • APN roaming protocol: IPv4
    • Enable/disable APN: <greyed out unless there are multiple APN's>
    • Bearer: Unspecified
    • MVNO type: None
    • MVNO value: <Not set>
  6. Tap the Menu icon with three dots, then tap Save.
  7. Tap the desired APN profile you want to use. The bullet point fills with color next to the APN profile.
Manual network selection
The device detects and registers on wireless networks inside T-Mobile's calling area, but roaming networks are usually restricted to T-Mobile SIM cards. You can manually select a network only in areas where T-Mobile does not own GSM spectrum.
  3. Tap Network operators.
  4. Wait while the device populates a list of available networks.
  5. Tap the desired network you wish to register on.
Switch 2G / 4G
  3. Tap Preferred network types.
  4. Choose from the following options:
    • LTE/WCDMA/GSM (Auto mode)
    • WCDMA/GSM
    • GSM only
Turn on / off airplane mode
Airplane mode turns off wireless connections. This allows app and menu use, but prevents voice or Internet use.
  1. From any screen, swipe down from the top of the screen.
  2. Tap the down icon (v), the tap Airplane to turn on or off.
Turn on / off data roaming
  3. Tap to turn Data Roaming on or off.
Turn on / off mobile data
  1. From any Home screen, tap Apps > Settings > Data usage.
  2. Tap to turn Cellular data on or off.
From - https://support.t-mobile.com/docs/DOC-28547
If you need further help, I’m available over the phone at https://www.6ya.com/expert/daniel_a4640839dbb7ec58
How do I change billing to different credit card, and can I make calls from Europe while using my Consumer Cellular card?
FIXYA unpaid volunteers cannot arrange your cellphone or credit cards.
It appears you are asking about cell phone calling but I may have misunderstood your question.
Call Consumer Cellular Customer Support toll free at
(888) 345-5509
https://www.consumercellular.com/Help/international-rates/roaming
You can use your Consumer Cellular service when traveling outside the U.S. by enabling international roaming. The countries where our service can be used are listed here.
Consumer Cellular utilizes multiple network providers. The network provider your specific cellular service uses determines international roaming availability. To confirm your international roaming options, contact Customer Support at (888) 345-5509. We recommend doing so at least two weeks before leaving the U.S.
On some networks with Consumer Cellular, usage incurred from the countries listed will be billed at international roaming rates of $0.30 per talk minute, $0.10 per text message, and $0.25 per MB of data usage. On other networks with Consumer Cellular, those costs can be much higher, or international roaming may not be available. Be aware that when using your phone internationally, charges can add up, so it is always best to use on a more limited basis. For your protection, service will be disabled once we have received billing records showing $50 in international roaming charges has been incurred on your account during a billing period (this includes calls, text messages, and web data). Due to delays in receiving billing records, your charges will likely have exceeded $50 when international access is disabled.
How to roaming
You can go to Settings, then Cellular Data. There's the "Data Roaming" switch that you could turn off.
Have a nice trip!
Feb 02, 2014 • Cell Phones
My lg phone says im roaming when im not and it wont let me send out text's or recieve
Your phone is programmed with parameters to trancieve from a particular network. It roams when you're outside the coverage area or when the programming parameters have been altered in some way. Check your settings or refer to the network's programming unit to have the parameters entered correctly... then you'll be connected to the network services.
Alltel Bill question
On Alltel U prepaid, you get two free features for 75 cents a day, three for $1.00 a day, and four for $1.25 a day.
The four features offered are unlimited text messaging, unlimited night and weekends (N&W), unlimited mobile to mobile (M2M), and unlimited calls any one number. You decide which ones you want.
The fee is charged every day, regardless of usage or not.
The only way to not get charged every day is to switch to the pay-per-minute plan or get a monthly plan.
Help with kyocera strobe on alltel network
I asked Alltel customer service and they said the phone is not capable of it. Mine come through as symbols. I just bought this phone on Ebay but it will be back on Ebay shortly.
My 7135 kyocera is locked to verizon service i need the code to unlock so that i can use the phone with my current service provider,the phone is a gift my sister the previous owner
Hope this helps!
- 2 Bunny
Alarm beeping
Not sure, but the 1x active may have to do with some time of alert that you may have accidentally set in your calendar or alarm clock. Check your calendar and alarm for active alerts.
My picture messaging aint working
I am having the same problem with mine and I am with Alltel and they have no clue
2answers
Help programming my phone
I've figured out a solution so hopefully someone else with the same problem wont have to go thru my pain. I tried everything and tried the codes from the SphA900.
##000000# and it will give you an option to edit or view. hit enter and change the MSID number to your phone number. I did that and It enabled the flashed Samsung A740 onto the cricket system. I can make and rec calls now. when you go to settings and phone info the number should show up
Top Kyocera Computers & Internet Experts
NOEL
NOEL
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Kyocera Computer and Internet Expert? Answer questions, earn points and help others
