Question about HP Officejet 6700 Premium E-All-In-One
Can't change Fax Settings on HP 6700 Printer
I want to change the Fax settings on my HP 6700. But they are shown as locked & I get a message saying they were locked by the administrator. Since this is my own personal printer at home, I assume that I would have the ability to do this. I just don't know how. Can you tell me what to do? Thank You
Posted by martyschor on
bayou sam
    Passionate:
    Visited the website for 10 consecutive days.
  • 126 Answers
You might want to do a full factory reset, the usual solution if you are locked out of the machine due to not knowing the administrator's password. Details about how to do this for your HP 6700 are available here -
Full Reset HP OfficeJet 6700 All in one Printer
Posted on Dec 23, 2017
matt
  • HP Master
  • 1,648 Answers
4 Related Answers
Anonymous
SOURCE: hp 1210 all in one printer - error message
This is how to reset your HP PSC 1210:
* Set your computer system date to a date before the expiry of the ink cartridges.
* Start the following program:
C:\Programs\Hewlett-Packard\Digital Imaging\bin\hposvc08.exe
* Use the password "Homer"
* Choose the reset directory
* Hit the total reset button
* Follow the instructions ...
Posted on Aug 29, 2008
Anonymous
  • 432 Answers
SOURCE: Printer "out of memory"
The problem isn't your printer. The problem is with your Microsoft Works software. I know of six solutions that may work.
1) Download the latest service pack for .NET Framework 1.1. http://www.microsoft.com/downloads/details.aspx?FamilyId=A8F5654F-088E-40B2-BBDB-A83353618B38&displaylang=en
2) Go to this website and download the update. http://www.microsoft.com/downloads/details.aspx?FamilyID=65f5b806-e6a1-4f92-a656-e56eeda67e3d&displaylang=en
3) Uninstall printer completely (again). Unplug the printer from the computer. Reboot computer. Download the lastest driver from HP website. When installing the driver software, choose (type)a different directory,( ie. C:\MYHP\HP4180\ ). Plug Printer back to computer.
4) Go to this website. http://support.microsoft.com/kb/841220
5) Click START, click RUN, type SPOOL. Double click printer folder, clear (delete) any files in this folder.
6) Download the latest version of Microsoft Works 9.0.
Let me know if this works.
Posted on Feb 03, 2009
bravsman
Joel Cruz
  • 94 Answers
SOURCE: "printer is currently off-line. offline" use a mac
check the usb cable of printer try to reconnect it and make sure you use usb port in your printer properties
Posted on May 25, 2009
stonerfam623
stonerfam623
SOURCE: HP 6700 printer change ink cartridge
http://images10.newegg.com/User-Manual/User_Manual_28-415-214.pdf
Open ink access door.
1. Make sure the printer is turned on. Never turn off the printer when ink cartridges are missing.
2. Open the ink cartridge access door. [This is the panel that is to the left of the touchscreen. To open, put your fingers on the upper left hand side of the panel (by the logo: HP OfficeJet 6700 Premium), You should be able to gently pull the panel so that it opens out.]
NOTE: Wait until the print carriage stops moving before proceeding.
3. Press the front of the ink cartridge to release it, and then remove it from the slot.
4. Remove the new ink cartridge from its packaging.
5. Using the color-coded letters for help, slide the ink cartridge into the empty slot until it is securely installed in the slot.
Replace the
Posted on Sep 20, 2012
All settings on printer are shown as "Locked". I didn't lock them and can't unlock them.
Try accessing the Embedded Web Server in the printer.
e.g. HP Photosmart C4380 All in One Printer Series and C4550 C4580 and C4585...
(the EWS can be accessed in the 6700 series All-In-One printers using the same process as in those printers.)
Jun 16, 2015 | HP Officejet 6700 Premium E-All-In-One...
How do I replace the ink cartridges in my H711n printer?
Please follow the link will show how to change :
http://www8.hp.com/h20621/video-gallery/us/en/customer-care/printers-and-all-in-ones/replace-ink-and-toner/1655134310001/replacing-a-cartridge---hp-photosmart-7510-e-all-in-one-printer-c311a/video/
Mohamed Hejazi
HP TECH. SUPPORT
Afaqnama - Tripoli - Libya
Mar 18, 2013 | HP Officejet 6700 Premium e-All-in-One...
No fax log in my J4680 running Mac Snow Leopard 10.6.8. The manual says you can view the fax log for my J4680 AIO printer. It is nowhere on my drive. HP had me uninstall all HP software and reinstall. HP...
If you have reinstalled the software what to do is open up the hp utility which is located in the applications folder and then the Hewlett Packard folder from this application you can then choose under fax settings the fax logs button and this will show you the fax logs for the printer. Hope this helps. The link to the HP software is at http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=219&lc=en&cc=uk&dlc=en&sw_lang=&product=3692888#N201
Oct 29, 2011 | HP Officejet J4680 InkJet Printer
How can i remove the password of my printer settings???
Try doing an NVRAM initialization that will return the following device settings to the factory-set defaults:
a.? All menu settings, including the fax header and company name
b.? Fax numbers and names that are associated with one-touch keys and speed-dial codes
c. All faxes stored in memory are cleared.
Steps:
1. Turn off the product.
2. Press and hold both the down arrow button and the Cancel button, and then turn on the product.
3. Wait until the message Permanent storage init. appears, and then release the buttons.
When the NVRAM initialization process finishes, the product control panel shows the Ready message. Hope this helps.
Jun 09, 2011 | HP LaserJet M1522nf Multifunction Printer...
How to change the fax # on my HP J4680 all in one printer
if you are asking how to change fax header,here's how:
on the printer push wrench button or setup ,push right arrow to go to fax settings,hit ok,fax header,hit ok,enter your name then your fax number ,hit ok
May 27, 2011 | Office Equipment & Supplies
My cat sat on the buttons so much that the language change how do i change it back?
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Oct 31, 2010 | HP PSC 2210 All-In-One InkJet Printer
I am trying to use your fix for the "ink system error" message on my HP Officejet 6500 Wireless but when I press and hold the * button and press the # button all I get are 5 *'s and 5#'s on the screen. I...
Please perform these resets on nit or change printheads if it will not work.
1.
Press & hold the power button > unplug the power cable from the back of the printer while holding the button for 30 seconds > plug the cable back then release the button.
2.A semi-full reset will do the following:
Jul 27, 2010 | Office Equipment & Supplies
The cartridges are stuck to the right and the door won't lock?
Jun 23, 2010 | HP PSC 2210 All-In-One InkJet Printer
The relpacment printer locked up even before i hooked it up. to the lap top same problem as the first printer. it freezes and will not even turn off. hp officejet wireless 6500
Perform this reset
Jul 11, 2010 | HP Officejet 6500 Wireless All-in-One...
HP Officejet 6700 Premium E-All-In-One Logo
191 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
