2004 kawasaki VN 1500 Vulcan Classic Logo
Posted on Jan 23, 2009
Clutch slipping while cold, when warm/hot, it operates great.
Clutch slipping while cold. When warm/hot, it operates great. When I first put the bike into gear, the clutch seems to slip, and the bike starts to move but only at a walking pace 10mph.
Engine power and throttle good. Once I have traveled about 1/2 mile and shifted up into fourth gear (engine very warm), The clutch comes to life as advertised. From there on, I have no problem with accellerating.
When I stop for a few hours and the bike cools, I go thru the same problem and solution
Kevin Reaver
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Jan 26, 2009
Kevin Reaver
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
0
Helped
4175
Points
9
I have a 2000 Vulcan Nomad FI & had a very similar problem. In fact, it's a very common problem with these bikes. I fixed it by replacing the Clutch Spring. (As Described here: http://www.gadgetjq.com/clutch_spring_replacement.htm
It cost me $40 and 3 hours of time with an impact wrench.
2answers
When I start up my bike I pull in the clutch lever put it into gear the bike shuts off and lunges forward.
Clutch problem - please help - Dirt Rider Magazine
forum.dirtrider.com/discussion/6668452/clutch-problem-please.../p1
18 posts - ‎9 authors
I start the bike in neutral with the clutch pulled in, then I shift into first and it will kill ...bike, if you put the bike in gear and try to roll it (even with the clutch lever pulled ...Started it back up, gave it enough throttle to keep it from stalling, put it in 1st, ... I continue to change the oil in my clutch but almost immediately it turns white.
Re:Always shuts off putting it in first!! - Road Star Forum ...
roadstarclinic.com > Forum List > Technical Corner > Maintenance
Jun 17, 2014 - 10 posts - ‎8 authors
My 99 Roadstar has the habit of always shutting off when I knock it into first ... pull in the clutch and put it in first gear the bike lunges forward and shuts off. ... Hold thefront brake ALWAYS when shifting a cold bike into first. ... What I do on cold starts is to select first gear with the motor off, pull the clutch in and ...
How To: Fix 5 Common Bike Issues ' RideApart
https://rideapart.com/articles/fix-5-common-bike-issues
Jul 21, 2014 - It's easy to assume the worst when your bike isn't opperating perfectly, ...Where's my ignition! ... First, ensure the battery is good and that the engine turns over.... Try starting with the kickstand up, clutch in, and bike in neutral and see if the ...goes away most the time when the bike is put into gear or revved.
Checking Your Yamaha Ultramatic Drive Belt - YouTube
? 9:35
https://www.youtube.com/watch?v=vgh4TzSgCB0
Oct 9, 2010 - Uploaded by 6speeddakota .
1helpful
2006 v star 1100 classic w/ vance + hines slip on exhaust. I get popping at idle and decel (i'm thinking it just needs to be rejetted). The big problem, is when the bike has already warmed up (at least 5...
The popping at idle and deceleration (when the throttle is in the idle position) could be a lean mixture at idle.
A lean mixture sitting at idle for a long light would cause the engine to run hot.
Also, as the engine reaches operating temperatures, the idle will pick up.
1helpful
2answers
Finding neutral
This is usually down to clutch adjustment.If the bike shifts into neutral at stand still but doesn't when hot then your clutch cable needs adjusting so you have 1/8th of an inch freeplay at the lever. Also try running on a 20/50 oil as these bikes weren't designed to run on synthetic oils( clutch slip ) Also warm the bike up properly before a ride , don't tear off with the engine cold. Happy riding.
1helpful
2answers
What make and type of crankcase oil is recommended. More less have this bike with no manuals.
Been running mine now for 36,000 miles on Castrol GTX 10W40, and have had no problems!
2answers
Clutch slips
Old fluid or improper type. Doesn't the Sporty use the SportTrans fluid in the year? Other than that, maybe time for new clutch plates. Or the clutch spring may have lost it's spring.
Won't idle down after it warms up
after the bike has warmed up, then reset the idle to approx 1000rpm. then see what happens when its cold. some bikes are cold blooded and the use of choke is necessary for a bit, at least until it warms up...
91 250 Bandit clutch/gearbox probs?
Keep in mind that a wet clutch requires special oil and adequate free play to make sure the clutch is fully engaged. Chk both. Regular engine oil wreaks havoc on wet clutches. good luck
84 honda shadow vt700 clutch slips when hot
Your clutch plates have lasted 25 years. It is probably time to get some new plates. Have your dealer get you a set of Barnett clutch plates.
2answers
Noisey gearchange
Hi Al,
I know you are looking for feedback and I hope I can help.
I have a FLHR Road King Harley Davidson and believe me It clunked real bad when I bought it (7,000 miles), I checked the clutch primary chain, well within tolerance, also Clutch plates too.
I know your engine is wet sump and the gearbox uses the same oil as the engine?
I changed my gearbox oil and also double checked level as the amount that came out wasn't enough?
Since then pure smooth cold & Hot, so maybe the wrong viscosity oil? Nice & Thick cold but when thinned due to warm up and at operating temp not coating the gears so bulk rings failing slightly?
There you go one to look at?
Press the Blue Button please to appraise my FREE! Effort/s, Thank You!
Paul 'W' U.K.
Top kawasaki Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Bob G
Are you a kawasaki Expert? Answer questions, earn points and help others
