I have a GE Profile fridge. When I dispense ice out of the icemaker the flap stays open and all the ice in the fridge proceeds to melt a bit. Water is working fine. I tried cleaning the flap as best as one can. How do I open the unit up? And how do I get the flapper to stay shut.
SOURCE: Ice maker
I had the same problem with the ice dispenser flap not closing properly, this cause very large build up of ice around the inside - get that sorted first.
SOURCE: GE Icemaker flap door won't open causes ice jam in chute
There is an electric solenoid that opens the door. If you look up inside the dispenser you can see the solenoid. Either the solenoid is bad or the dispenser module that puts power to it is out. You will need to remove dispenser front and check for voltage to solenoid. If you have power from module, replace solenoid, if no power, replace both parts. It is common for solenoid to short out and damage the module so that both must be replaced. If solenoid is shorted and you replace module, new part will fry.
SOURCE: ice maker not working
So your not getting water from the dispenser either??? Yes the water filter can be the source of your problem. Let me know if the water is coming from the dispenser.
SOURCE: GE Profile side by side fridge - water dispenser doesn't work
More than likely, your water line is freezing up in the door. You can remove all of the ice cubes and lower the freezer temp to about 3. Leave the freezer door open for about 5 minutes or so and if this does not work, leave the door open a little longer. Also, disconnect the water line at the base of the freezer door, near the floor, and press the dispenser lever. If you have water there, you most likely have a frozen line in the door. Changing the water filter often will help but it is not the answer and is can get quite expensive. By the way, Make sure to hold the dispenser lever forward for at least a couple of minutes each time you test for water flow. If you do not get water at the connector at the base of the door after you have disconnected the line, you have a problem with the valve in the back of the refrigerator.
SOURCE: GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
