Question about Motorola Mobility RAZR V3xx Cellular Phone
MOTOROLA RAZR V3XX--Searching for Network?.
I have a Motorola Razr v3xx and whenever I turn my phone on it just keeps saying 'searching for network' and it never finds network. I don't know what my problem is. I know that it isn't my sim card because whenever I go and put my card into my old phone, it works just fine it's a failure with this phone and I don't know what the problem is but it just simply never finds any network, please somebody help me?!.
Posted by itsspeytonho on
  • Anonymous Feb 05, 2009
    I am having the same problem. Any suggestions?
  • Anonymous Feb 09, 2009
    i have same problem
Need to unlock Motorola Razor V3xx cingular to work on Verizon
It's not possible as the two networks are not compatible with each other for the V3xx. With other phones it may be as easy as swapping SIM cards.
Motorola Support
Apr 12, 2014 | Motorola Mobility New 3g Razr Razor V3xx...
Subsidy code
If you need Subsidy code for your Motorola RAZR V3xx mobile phone visit TheUnlockSpot.com Here you can remove your network lock at low cost.
Nov 16, 2013 | Motorola Mobility RAZR V3xx Cellular Phone
Need subsidy password motorazr v3xx my ime number is 354094010174808
Hi to get subsidy password visit mobileunlocksolutions.com here they ask you the network name to which your mobile is locked and the imei number of your mobile .finally they send you codes to unlock your Motorola razr v3xx mobile.
Aug 14, 2012 | Motorola Mobility RAZR V3xx Cellular Phone
MOTOROLA V3XX SEARCHING FOR NETWORK
CROHUNTER - you should take it to a mobile service center and ahve it tested the board antenna may need servicing.
Aug 28, 2008 | Motorola Mobility RAZR V3
Razr V3XX searching for network
you must have a crack in the phone board IC or RF related so take it to a mobile shop to see if that happening.
My razr v3xx keeps searching for network
maybe the antenna is not in correctly...you should take the phone to a mobile shop and have them check it over for you.
Aug 06, 2008 | Motorola Mobility RAZR V3i Cellular Phone
How to i change my motorola mobile phone to dual band network
You need your phone unlocking this should cost you around £10this will enalbal you to accsept all networks
Jun 18, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Razr v3xx celluar
Usually that only happens if the phone was just turned on, so the camera takes time to warm up. Try restarting your phone and try again. Hope this helps =)
Feb 25, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Motorola Mobility RAZR V3xx Cellular Phone Logo
241 people viewed this question
Top Motorola Mobility Cell Phones Experts
Vernon Taylor
Jeff
Harrie
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
