Expert
- Posted on Jan 13, 2013
Re: I have a ev205 yamaha violin its covering of the...
Instructions
Check the main power cord if the receiver fails to turn on.
If it is unplugged or loose, securely plug it in to an electrical
outlet. If this fails, try plugging the receiver in to another outlet.
If the receiver starts, the previous outlet is damaged. Call an
electrician to repair it. If this fails, try turning the receiver on
with the remote. If this does not turn the receiver on, try turning it
on with the power button on the receiver itself. If this works, change
the remote's batteries.
Leave the receiver in "Standby" mode if it immediately goes
into "Standby" when you turn it on. With the receiver still in
"Standby," unplug the main power cord. Wait for around 30 seconds, then
plug the receiver back in.
Check the audio cables if you experience sound issues. If
they are loose or disconnected, securely reconnect them. If you still do
not have any audio, press the "Input" left or "Input" right buttons on
the front panel to select the appropriate input source. You can also set
the receiver to automatically detect input signals and select the
appropriate input source. To do this, access "Audio Select" from the
main menu and select the "Auto" option.
Try factory resetting the receiver if you experience
persistent audio or video issues. Press the "Standby/On" button on the
receiver's front panel. Press and hold the "Tone Control" button, then
press "Standby/On" again. Select the "Preset" option, then choose
"Reset." Press "Standby/On."
