Garmin StreetPilot 2620 GPS Receiver Logo
mon bautista Posted on Jul 06, 2007
GArmin 2620 My GPS turn on and it get to the "Loading map information" page and it shuts off, then it turns itself back on and off over and over again. I just used it few hours ago and it did work fine. Please help.
  • 2 more comments
  • Anonymous Nov 27, 2007
    rebooting
  • Anonymous Feb 12, 2008
    I have the same problem, just talked to garmin about it, they said send the unit in and they will send me a rebuilt for $275, just swap it out for me, I will think about it for a day or two. Tech guy told me the unit lost it operating system, they can only fix it in house.
  • Anonymous Feb 19, 2008
    I have a same problem, and I think I can fix it, may be not. Any how, I bougth a cornice drive on ebay and as soon I will get it. I will load my maps on to it with usb connector after that I take it a part and remove it from its case. Then I will take my Garmin Streetpilot 2620 apart remove the old cornice drive and install the new drive. I suspect it will work like a charm.
  • Anonymous Apr 05, 2008
    won't boot
Anonymous
Level 1:
  • Contributor 22 Answers
  • Posted on Apr 14, 2008
Anonymous
Contributor
Level 1:
Answers
22
Questions
0
Helped
21469
Points
36
In February I posted that I will replace the cornice drive on my 2620 because I had this problem GArmin 2620 - 019d1f6.jpg Well I did that, but could not fix the problem. Garmin is asking $275 to replace my unit, I did not wanted to pay them that much. So I bought a 2610 at eBay for a $100 and don't have to worry about hard drives any longer.
To get this screen on a GPS push "menu+find" and then turn on unit. It will show this diagnostic screen.
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Mar 22, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1007
Points
When i loaded the 4.80 update, it started doing this. Loading map, then reboot, loading map, then reboot. After a while it would boot up. If the unit was warmed up, it would not do it. I back-reved the 4.80 to 4.70. It erased all my way points and reset to factory defaults. Upgradeing to version 4.80 and other versions did not erase waypoints or reset your settings. I have City Navigator v7 and not v8. 4.80 seems more tailored to V8 and 4.70 is more for v7. It seems to work ok now, but need to try it out a few more times.
A
Anonymous
Can anyone please help me get to garmin 2620 streetpilot schmatic ? i would truly appreciate any help...thankyou very much
Akshay
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Dec 08, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
642
Points
0
Same problem and tried all reset software same problem. Any other ideas?? Heard there is a reset button but unable to find this.. Any help out there?? Thanks
A
Anonymous
Get the new update from garmin - 4.80
A
Anonymous
Cornice Drive is bad, Drive must be replaced through Garmin
A
Anonymous
Garmin nuvi 270 won't turn on
Stuck at the loading maps screen is often caused by a corrupted map or flash drive. The drive must be accessed in order to restore the corrupted map file or flash drive. More information can be found here:
SHARCNET USA Out of Warranty GPS Digital Camera Repair Center
3helpful
2answers
My garmin 1300T turned itself off and will not restart
This is likely a failed battery.
The battery on these units is not user-replaceable (soldered to the PCB) and must be returned to Garmin for repair.
CLICK HERE to see more about their FLAT RATE repair service.
Your 1300T is listed as a $99 flat rate repair.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
3helpful
The garmin 2620 will not load maps
You are caught in a loop most likely caused by a failed microdrive. Search Garmin 2620 cornice for a thread that is likely to provide the information about the failure you are experiencing. In short, if it is the Cornice drive that has failed you will find it very difficult to repair, if not impossible depending on your level of expertise and ability to find a used part for repair as the drives needed are no longer manufactured or readily available.
Garmin 2620
connect your GPS to your PC and load your local maps to the hard drive. Maybe update your firmware as well. Good luck.
3answers
Map update gone bad
Connect it to a PC and delete the map(s) using windows explorer.
Garmin streetpilot 2620
There is no reset button. Every time you turn off your Garmin and turn it back on it reloads everything fresh. What is likely the cause of what you are experiencing is a failed Cornice microdrive. It is near impossible to fix with the parts available today (May 2010) and it is more time management and cost effective simply to purchase a working 2610 from a third party site, or to purchase a new unit from the store that is still supported. In addition to the parts issue Garmin discontinued Map support for the 2620 (and 2610) in 2009.
2helpful
Most likely your hard drive is gone bad. Push "menu+find" buttons then turn on, you will get diagnostic screen, it will show if your cornice drive is bad. It will say"Cornice Dive removed"4f3efc6.jpg
3answers
Garmin Streetpilot 2620 Goes not go to maps
I would like to know the same thing! My father has the same unit and he updated his with version 4.80 & web updater (both free) on garmin and it solved his problem. I believe my problem is that my North America v8 did not install properly. ????? well see
7answers
Garmin 2620
still no fix, trying to find the original box so i can hook it up to the computer
Top Garmin GPS Experts
Marvin
Marvin
vince
Are you a Garmin GPS Expert? Answer questions, earn points and help others
