Question about Sony Cyber-shot DSC-W170 Digital Camera
Macro in sony W170 digital camera
I was inspired by the sony w55 of my neighbour and bought a sony w 170 digi cam recently. when i take a photo and then zoom in to that photo, the more i zoom the more blurred and grains it gets, where as in w55 the photos are very clear even while zooming till last. pls suggest if there is any change that has to be made
  • 31 Answers
The resolution of the photo you take determines how grain shows up as you zoom into the Photo, So taking a 10 megapixel photo on optical zoom or no zoom will give you a sharper picture than when you use both the optical and digital zoom to grab your picture. The digital zoom uses the centre of your CCD picture imager rather than the whole CCD so with less elements to your picture when you take it gives you blockiness sooner when you zoom in on the image. I am guessing your friend has digital Zoom turned off in settings to prevent the Graining showing upon magnification. Good light and a steady camera will give you the best results.
Posted on Dec 05, 2017
3 Suggested Answers
6ya staff
SOURCE:
Ty Price
  • 11967 Answers
SOURCE: I think my DSC-W170 got some minute grains of sand in
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 20, 2009
SkyHawk11
  • 5 Answers
SOURCE: i have sony DSC-W290 Cybershot
I would check and confirm that you are zooming using the optical zoom. It sounds like you may be zooming using the digital zoom, which would have this effect.
Posted on Feb 28, 2011
My DSC-W55 can not zoom when i recording a video, how can i fix it?
You can't. The DSC-W55 does not allow zooming while recording a video. See the second bulleted item under "Using the zoom" on page 15 of the manual.
Sorry if that wasn't the answer you wanted to see, but that's the way the camera is.
Aug 21, 2012 | Sony Cyber-shot DSC-W55 Digital Camera
Lens isn't coming out.
There is a mechanical displacement in your digi cam. May be due to shock or ****. Digi Cams are very delight, especially small ones. We have to handle it very carefully. Even a small **** can cause problem. Get it serviced as soon as to avoid any further problem.
Don't turn it on and off, it may lead to motor problem.
Please rate the answer if you find it useful.
Thanks for rating.......
Apr 29, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
" " lens pops in & out twice & the screen says access then screen says turn power off and on again. Sony Cybershot dsc w55
this problum is related with optic zoom lenz assy its not work propally so thats why screen shows access problum pleae go to your nearst sony service centre & fix the problum or repair optic zoom assy
Feb 05, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Zoom button
Some time Zoom switch knob got broken internally and resulted the problem as you have with this camera.
You can replace upper part of camera with following part number..
A-1246-250-A CABINET UPPER(240),BLOCK ASSY
It is an easy job to replace above part.
Part available in Parts Store for $24
Feb 02, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
CAN I UPLOAD PICS FROM MY SONY CYBERSHOT W55 USING A SANDISK??
what do you mean nothing happens???
the memory stick pro duo should fit right into the sony cybershot....
if your struggling to load your photos onto your computer buy a universal memory card reader!
you should try and use a memory stick in a camera that needs an sd though!
Oct 16, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Connection error (31)
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jan 21, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cyber-shot DSC-W55... Problem: "vibration warning" what is this?
My husband just discovered that it has to do with the flash setting. When the auto-flash and flash-on modes are on, it doesn't do it. When the "SL" mode is on - I get the Vibration Warning.
Nov 19, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cyber-shot DSC-W170 Digital Camera Logo
119 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
suresh Kulkarni
suresh Kulkarni
Are you a Sony Camera Expert? Answer questions, earn points and help others
