2004 Kia Sedona Logo
Posted on Jan 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2004 Kia Rio Won't Start Clicking Noise Battery is GOOD
We were driving and stopped to make a turn the car died... then we tried to start it and it tried to turn over but didnt start.... then it just made a clicking noise when we tried to start it... So we thought it was the battery so we got a new one and still same thing loud CLICK noise when we turn it over... It doesnt make a draging sound when we try to start it just a loud click and then nothing... Lights are bright and all and we even had the new battery tested and it is GOOD!
  • 4 more comments
  • dwightmstone Jan 22, 2009
    Here is why i dont think it is the starter.... We were driving and stopped to make a turn and it died. If it is a bad starter that wouldnt make it stop running? Would It?
    The old battery (we thought was dead) we had tested and it was OK still good...the guys at the auto parts place are saying it sounds like a fuse or relay of some sort.... any thoughts on if this could be the problem and what to replace.....
    it is an automatic.... where is the starter relay?
    Yes there is one in the box that says START (i guess that is it) and it is a large SQUARE one.... I will need to check it tomorrow and see if there is one to switch out and see if it works.... THANKS....
  • Anonymous Mar 22, 2014
    get start once and then turn off the ignition, tried to start again and won't start anymore. Checked the battery, still new, checked the fuse still good, start again can't hear any click from engine
  • Anonymous Mar 28, 2014
    my 2011 hyundai sonata will only attempt to turn over, we know the battery is good.
Anonymous
Level 2:
  • Expert 99 Answers
  • Posted on Jan 22, 2009
Anonymous
Expert
Level 2:
Answers
99
Questions
0
Helped
57062
Points
250
Sounds like the starter.
  • 1 more comment
  • Anonymous Jan 22, 2009
    no but if the alternator stopped charging, the battery would die and make the car cut off. If you continuously tried to crank it, it could have burnt the starter. See if you can turn the engine by hand to make sure it turns freely and has not locked up. The clicking sound is from the solenoid from the starter. You can take the starter off and have it tested at an Auto parts store for free.
    Is the car straight drive or automatic? It's not a fuse because if it's clicking it's getting power but it possible that it could be the starter relay.
    Under the hood in the black box that contains the main fuses and relays. It should be labeled, but it is under the hood. If there is another relay that has the same plug in and looks the same you can switch it to see if it works and if it does you just need to buy that relay.
John Sapp
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 01, 2016
John Sapp
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2257
Points
Had same problem. long story short, remove ground strap/wire and wher it is fastened to the fender scrape down to bare metal and reinstall securely, presto,works great. need a GOOD solid ground to carry the starters load
1helpful
2001 Kia Rio with brand new battery and alternator will start sometimes or with a jump but then shuts off. Jump it and it may run for a few minutes and quit again or work for days then just quit. ...
Sounds like you have a bad connection at the battery, wiggle the terminals they are very thin on that car. Check all your major grounds under the hood. All of that assuming the battery is in good condition
2answers
2004 kia rio won start
check your battery, starter or ignition.
___________
allscanner its3
My 2004 kia amanti just stopped running while i was driving it.it made a wierd noise somewhere in the front before it died. i tried to start it back up but it only made a loud clicking noise. we tried
Sounds like a bad battery or alternator, or it could have thrown the drive belt off. Check too see that the belt is still on and then charge the battery and see if it starts. If it starts, run for a while and dies again with no crank, it is most likely an alternator.
I went to start my 2005 Kia Rio this am and it sounds as if it is going to start followed by a clicking noise. Is this a battery problem or a starter problem? I have not replaced the battery since I...
SOUNDS LIKE BATTERY TIME FRAME FOR BATTERY IS 2 TO 7 YEARS DEPENDING ON QUALTY AND MAINTIANCE DONE 5 YEARS IS GOOD TIME TEMP MEANS ALOT TO BATTERYS ALSO TRY JUMPING AND IT WILL TELL YOU IF ITS STARTER OR BATTERY IF IT TURNS OVER GOOD LET JUMPER CABLE STAY ON FOR 10 MINUTES BEFORE STARTING AND BE SURE BGOOD CONNECTION IS THERE GOOD LUCK
1helpful
2004 Kia Rio suddenly dies while driving
check to make sure the vehicle is firing, by removing one of the sparks plugs wire and ground it our on the engine by placing a screw drive inside the end, if done correctly u should see spark
2004 Kia Rio
My Kia Rio Cinco is having problems. Sometimes I hit the gas and the car barely moves so I put it in park and tap the gas and finally it moves. It has happened 2 times.
Battery 11.37v but car died, etc..
charging voltage is 13.8 volts. battery voltage at least 12 volts. check charging system first
2helpful
3answers
My 2004 Kia Rio just started losing compression and died on me. I tried starting it and it only clicks. I checked the battery cables and they are not corroded and very tight. Could it be the battery or the alternator not charging the battery? there is no water in the oil and it's not the water pump.
2005 Kia Rio.
You probobly threw a timing belt wich in turn caused damage to the valves and piston heads. I just replaced my engine because of it.
Top Kia Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Kia Expert? Answer questions, earn points and help others
