When turn the TV on is starts looking for the dvd signal, then it says no signal. This is going through hdmi 1 cable spot. I tried the other hdmi plugs and got the same problem. When you turn the tv on and off 5 or 6 times it will pick up the signal. The bly ray player is a samsung BD-p1500 and my receiver is onkyo tx-sr606. any help would be appreciated. Thaks
The issue is with the main board circuits on your set not detecting signal on HDMI ports or selecting those ports.
How about your other inputs - do they work? Have a feeling they also will be dead. If course you can always feed the dvd rf signal to your set but the audio and video will not be up to current standards but it will work like that.
SOURCE: Unlocking of Samsung BD-P1500
I have a new BD-P1500, and after 5 Times
The trick seemed to be not holding the repeat key too long.
I have a Region B/4, running
090417_01_BDP1500_XAX.RUF
I used the R4 code from below.
1) Turn on the player with no disc in the tray
Wait till the unit is at the Samsung logo screen.
2) Open then close the tray, wait to see the No-Disc Message in the top Left Corner
3) Now press the REPEAT button on the remote, followed by a five digit code.
In this case Repeat 76884
Now it to me about 5 tries to get this to work, It needed to be done without delay.
So if you don’t get it to work straight away don’t loose heart.
4) When it works a 4 will appear in the top left corner
5) Press 9 to make it regionless.
6) Press Eject to OPEN to open the disc tray.
7) Press Eject to CLOSE to close the disc tray.
8) Power the unit off
9) Now power the unit on again, it should now read all regions of DVD Disc.
From other threads I got the follow list of region codes.
R1 - 29334
R2 - 57538
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
Report this hack (requests/questions/spam/wrong/****).-->
Region code hack posted by wasgo, September 17 2008:
I have tried the hack mentioned above on my new BD-1500 and couldn't make it work. But the software in it is about a month newer.
Does anybody have any new ideas how to solve the problem?
I have the region 2 version (Sweden)
SOURCE: SAM BD-P1500 Remote won't work with Sharp LC-32D43U
If you are trying to use the remote that came with the dvd player you most likely can't get it to work with the TV. If it IS in fact a universal remote, then you need to check the codes that come both with the tv and with the remote. Post back with any more questions or info for further help. Thanks for choosing Fixya!
SOURCE: Need code for included blu-ray universal to work with an Olevia TV
if Samsung never included the brand Olevia on there remote, then its not going to work because it was never design to work with that brand. The only way to get around that is to get a learning remote or universal remote that has olevia pre program into the remote.. Olevia did come out with some learning remotes that is able to learn from other remotes.. the model its called Olevia RC-LRN ..
This company called Amergence Technology sells the RC-LRN remote made by Olevia contact them at this toll free number 866-965-3842
SOURCE: Samsung BD-P1500 will not play blu-ray discs
it seems that samsung is posting it's firm updates online @ samsung.com i had same problem with my BD-UP5000 its connected to the internet when i go to the menue to update on the bluray player it said i had the latest update went online and found a new firmware on there web site, check samsung web site
SOURCE: When trying to connect my 4695D to a new Sony Blu
The problem has been solved. A previous post to this site was having a similar problem hooking up a Playstation Blu Ray player to the same TV.
A solution was posted to that problem and I followed the same instructions.
It has to do with the set up porgram on the Blu Ray component. You need to select Settings then 108024Bit needs to be set to off.
