Rangemaster 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range Logo
A
Anonymous Posted on Dec 19, 2017
J'ai une gaziniere rangemaster 110 leisure exactement comme celle sur la photo en bleu !! sauf que les bruleurs sont pour gaz de ville et je voudrais trouver les bruleurs gaz butane ?? je n'y arrive pas sur les commerce francais et sur internet j'avais trouver un site mais ils etait pas bon !! merciii
5 Related Answers
Anonymous
  • Posted on Feb 10, 2008
SOURCE: rangemaster leisure 110
Hi
Just to say we sorted the problem. Simply the bulb was out in the one oven. We replaced this and problem solved.
Carole
Anonymous
  • Posted on Jan 27, 2009
SOURCE: RANGEMASTER 110 Cooker FLAME FAILURE DEVICE fitting
My progress to date (20090127):
1 Turn off the gas supply to the oven
2 Turn off the electricity supply
3 Remove the oven linings
4 Remove the storage drawer
5 Remove the three screws holding on the bottom trim and the trim
6 Crank up the front roller
7 Pull out the oven carefully making sure the gas hose and electrical lead are long enough and not caught
8 Working from the rear of the Rangemaster, for the right-hand oven, remove the four screws on the corners of the large cover plate at the back of the oven about half way down on the left-hand side as viewed from the back.
9 Remove the cover plate.
10 Go to the front of the oven. Above the burner assembly, towards the left is a thin metal rod running front to back. This is held in place by a clip at the back and by the hole in the metal frame at the front. Remove the metal clip at the back using a pair of long-nosed pliers. Retain the clip.
11 This should release the metal rod (flame sensing device) and you should be able to push it through the hole and out at the back. It is attached to a long copper wire.
12 Go to the back of the range. You should be able to work the wire back through the hole in the rear metal plate and up to the gas valve. The wire is held in place at the gas valve by a bent clip on the rear right. Carefully bend this clip back towards the oven to release the wire.
13 The wire goes down under the gas valve and to a threded bolt end into the bottom of the gas valve ad the bolt is held in place using a locking nut.
14 Remove the locking nut using a small spanner. The threded bolt should now turn, with the aid of long-nosed pliers.
15 The next trick is to remove this threaded bolt on the end of the copper wire and I have not figured out how to do that. It will unscrew a good way but becomes tight and will not come out, as though something inside the valve is holding it in place. Could it be that the flame sensing device has to be removed and inserted from inside the gas valve? If so, what a daft piece of engineering this is.
16 HELP.
Anonymous
  • 13 Answers
  • Posted on Nov 08, 2009
SOURCE: hello where will i find my serial number on the
Remove the drawer and the sticker will usually be on the right hand side of where the drawer goes in.
Danny
  • 160 Answers
  • Posted on Dec 18, 2009
SOURCE: i have a leisure rangemaster 110 double gas oven
the flame safety device need replacing (FFD)... this lets the full gas through when flame is sensed... safety 1st as a gas engineer will be required..
Anonymous
  • 149 Answers
  • Posted on Mar 27, 2010
SOURCE: I have a leisure rangemaster 110 dual fuel cooker.
at the back of the timer/clock there are 4 wires live and neutral to power the timer/clock and 2 others they may be red or orange. safely connect these other 2 together and you are good to go. if you need a new clock email me [email protected]
1helpful
2answers
J'ai un probleme dans pc hp compac perisario c700 systeme 7 je trouve pas driver du touch pad
Regardez sous l'ordinateur portable pour le numéro de type précis et trouvez ce numéro de type ici:
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?...1957&prodSeriesId=3466274
Vous trouverez le conducteur de touchpad sur le site Web précédemment mentionné. Téléchargez le conducteur et l'installez.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
1helpful
Notice d'utilisation
Bonjour KRACOT, s'il vous plaît excuser mon français. Je me rappelle un peu le français d'il ya longtemps ..Vous pouvez télécharger le Manuel de l'utilisateur en anglais sur le site Kitchenaid à: : http://www.kitchenaid.com/flash.cmd?/#/page/home.
Cliquez sur Customer Care>Locate Manuals& Guides> et entrer le numéro de modèle de 6 caractères, dans votre cas K45SSW et sélectionnez le fichier correspondant à votre modèle qui apparaît sous Owners Manual (2 K45SSWH-0.pdf (2730.37 KB) et à sauver cette fichier sur votre PC.
Mai aussi vous voulez télécharger le fichier sous Parts List Manual (1) K45SSWH0.pdf (341.41 Ko). (Cocher Certainement pour voir ce qu'il répond à votre table de mixage).
La liste de pièces manuel fournit une vue éclatée pour le démontage et le remontage de votre console, avec tous les noms et les numéros de partie, au cas où vous souhaitez commander des pièces de rechange pour fixer vous-même la table de mixage.
Bonne chance. J'espère que ce sera utile afin que vous puissiez utiliser votre mixeur KA. Howard, Burke, VA, USA
Si cette solution a été utile, s'il vous plaît notez le, merci! hslincoln
On me propose d acheter d occasion une imprimante lexmark x 11500 au prix de 50euro. pouvez vous me dire en fran?ais si c est bien et se ce mod?le va s adapter a mon ordinateur qui est tout simple, de...
D'occasion a mon avis ( j'en ai un ) c'est cher ! mieux vaut en acheter un neuf pour quelques euros de plus - au moins il y a une garantie -
Je vous avertis a l' avance que l'encre est SUPER chere ! mais tout depend de vos besoins - le mien marche bien, pratique, mais finalement pour une copie par exemple, a mon avis, mieux vaut aller a la boutique du coin ! (parce que l' encre est si chere !) - mais ca depanne quand on est presse -
Le scanner marche bien - par contre je ne sais toujours pas comment imprimer les photos sur papier photos... Lexmark ne semble pas avoir d'encre speciale photo - je n'ai pas essaye l'encre normale sur papier photo avec cette imprimante, parce que mes essais avec une autre n'ont pas marche ....
J'espere que ca vus donne une idee ....
Je nai pas de pression au bout de la brosse
Je suis désolé mais Fixya a seulement une version anglaise en ce moment. Cependant ce site vous permettra de copier et coller n'importe quelles réponses vous pouvez devoir votre problème pour que vous pouvez les lire en français. Vous pouvez taper aussi votre question sur ce site et cette copie et ce passé la traduction l'anglais sur Fixya pour une réponse plus rapide des experts.
Le site de traduction mentionné est un site de traduction libre. Juste être sûr de choisir les langues correctes pour la traduction à et de.. (L'anglais à français ou français à l'anglais) et utilise le bouton de Traduction LIBRE.
http://ets.freetranslation.com/
Merci pour utiliser de fixya. ..and j'espère que ceci aide ! ! !
J AI BESOIN DU CD D' installation de konica 7410 , copier , fax e
They lost/misplaced the installation CD, and they need to know where to find the drivers.
Les excuses, mon Français sont mauvaises.
Si votre recherche des conducteurs et du logiciel téléchargeables, dirigent votre web browser vers
http://konicaminolta.ca/
là où vous pouvez choisir la langue française pour une navigation plus facile. Une fois que là, cliquent sur dessus "Service et soutien", puis "Pilotes", puis "Drivers (Pilotes)" -> "Konica Drivers (Pilotes)" -> "Black and White Print Systems", et vous devriez pouvoir trouver 7410 dans la liste. Quel programme vous devriez employer alors dépend de l'OS de l'ordinateur à installer dessus.
Espérez ce toutes les aides. Sinon, faites-le moi savoir.
-Backu
EASYSHARE 5300 All-In-One
j aimerais si possible que vous me répondiez en français s.v.p
A la première installation , tout allait bien et les couleurs y étaient toute ...
par ignorance , dans la fenêtre Propriété de Document Kodak 5300 AIO
dans l'onglet général, à la question Mes Préférences . j'ai pris pris un des 2 choix et je me souviens pas quoi, et a partir de là , les couleurs on changé.
ce n'est pas grand chose, mais je ne comprends pas pourquoi
les couleurs n'ont pas d'éclat
le pire c'est la couleur rouge
c'est très décevant
C'est n'est pas la première imprimante que j'aie,
sur la page de démonstration , le lettrage est gris pâle , et le tour des yeux sur la photo des enfants est blanc.....
et lorsque que je lui demande un diagnostic il n'y a rien s'écrit sur la page
merci à l'avance ....
Lucie
Puis-je avaoir un support en fran?ais
Ton check engine n'a rien avoir avec les bougies.
Pour les cables, au pire remplace les une par une, comme ca tu te trompes pas.
Devrait emmener ca au garage pour ton bruit, sinon dit moi avec plus de details de c quoi ce bruit la. Bonne chance.
1helpful
Cam?ra embroyer..
Pourquoi les images provenant de la caméra sont-elles déformées, floues, granuleuses ou décolorées? trnsp.gif Réponse Plusieurs facteurs ont une incidence sur la qualité de vos images. Si les images sont floues, réglez la bague de mise au point située autour de l'objectif. Vous pouvez ainsi réaliser la mise au point sur des objets situés à des distances différentes. Veillez également à ce que l'éclairage soit adéquat. L'amélioration des conditions d'éclairage influe considérablement sur la qualité des images.
Si la qualité des images est médiocre pendant une transmission vidéo sur Internet à l'aide de programmes comme MSN Messenger, Yahoo! ou AOL Instant Messenger, votre vitesse de connexion à Internet a une incidence directe sur la qualité de la vidéo transmise. Les connexions d'entreprise de type modem câble, DSL ou RLE permettent d'obtenir d'excellents résultats en termes de qualité d'image, alors que les connexions commutées engendrent une qualité globalement médiocre et instable en raison de la lenteur de la connexion. Il peut arriver que la vidéo soit instable même avec les connexions haut débit (comme DSL ou modem câble) en raison du trafic Internet ou de la lenteur de téléchargement. Si l'image apparaît clairement sur le logiciel de la caméra, il est fort probable que votre connexion Internet soit à l'origine de la mauvaise qualité des images dans votre programme vidéo.
Si malgré tout, les images obtenues sont toujours déformées, floues ou granuleuses, vous devrez peut-être modifier les paramètres d'affichage. Pour une qualité optimale, vérifiez que la résolution est réglée sur Moyenne (16 bits) ou plus. Pour modifier la palette des couleurs:
  1. Cliquez sur Démarrer, puis Paramètres et Panneau de configuration.
  2. Double-cliquez sur l'icône Affichage.
  3. Cliquez sur l'onglet Paramètres.
  4. Dans la section Qualité couleur, vérifiez que l'option Moyenne (16 bits) ou Elevée (24 bits) est sélectionnée.
  5. Procurez-vous également les pilotes les plus récents auprès du fabricant de votre carte vidéo.
Si vous ne pouvez rien faire pour améliorer les conditions d'éclairage, certaines caméras vidéo Logitech sont équipées de l'option Optimisation de la lumière variable. Si tel est le cas pour votre caméra, activez l'option Optimisation de la lumière variable dans le logiciel QuickCam. Pour ce faire, procédez comme suit:
  1. Lancez le logiciel QuickCam.
  2. Dans l'angle inférieur droit de la fenêtre vidéo, cliquez sur la flèche en regard de l'icône QuickCam.
  3. Sélectionnez Paramètres de caméra avancés.
  4. Dans la section Amélioration de l'image, activez l'option Optimisation de la lumière variable.
  5. Si la qualité des images ne s'améliore pas, essayez de régler les autres paramètres, tels que le contraste, la saturation, la luminosité, le gain et l'équilibrage des blancs.
  6. Cliquez sur OK lorsque vous avez terminé.
Enfin, vérifiez que vous utilisez la version la plus récente du logiciel
Top Rangemaster Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
