When I check the default settings, the "scan to" destination displays as the proper scan folder. However, there is no destination in the "scan to" folder and there is no location in the drop down to allow me to select one. The scan happens then I receive a message there is no destination to scan it to. How can I remedy this? Is there some log I can clear somewhere? I have uninstalled and reinstalled the HP printer software.
SOURCE: HP C5280 SCAN/UNINSTALL
The uniinstall is not on the cd but on the computer.
Disconnect the printer. Then
START _ CONTROL PANEL _ ORINTERS AND FAXS. Highlight printer_ REMOVE.
Plug printer back in then run the install CD.
PS make sure install CD says thati t is for the windows version that you are using.
SOURCE: HP Officejet 6500 No scan Options
I am trying to scan, but when I press the scan button it states "No scan options. Refer to device doc to troubleshoot". However, I can't find my device doc. I am assuming there is an easy fix?
SOURCE: I have a printer software problem.
Have you run the check to make sure you have the latest drivers option on the HP website. You can also download the compatible version of the HP Solution Center from the same site.
Let me know if this helps you solve this problem. Thanks.
HP Site is
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&lang=en&product=1141647
SOURCE: Try to print but: get General Printer error 0x61000f6 beware spam number 1*800*532*4187
Hi
This error comes due to carriage jam. Turn off the printer and unplug it from wall socket. Now, remove the cartridges and check for any dried up ink residue on cartridges on inside the carriage. Clean the cartridges contacts and carriage using a Q-tip dipped i alcohol. Let the carriage and cartridges dry before you plug in the printer.
Install the cartridges and check. If it still shows error then unplug the power cord coming to the printer without switching it off. Now, remove the rear door of the printer and check for any paper jams over there, remove if any. Wit for at least 15 seconds and plug in the power cord. Now check whether it is working.
Daniel Scott
Testimonial: "Thank you very much for the information. very helpful. I am sure this information will help other people as well. Thanks again. "
