Question about Canon MP610 Photo All-In-One Printer
My Canon MP610 is stuck on a job on hold. Cannot delete it or resume printing. Tells me it is error 300 but cant find what this means. have triple checked all connections, usb and power, help! Read more: My Canon MP610 is stuck on a job on hold. Cannot delete it - printers/canon-mp610-stuck-job-hold-cannot-delete.
Smith William
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • Canon Expert
  • 241 Answers
If you're facing Such Issue then don't worry have a look, your solution is here
Try out any of these solutions to fix Canon Printer Error Code b300: §Turn off the printer, disconnect the power cord from the electrical outlet. Now, you should hold down the power button for a minute. Then, reconnect the power cord to the electrical outlet and switch on the printer
§You can also clean the ink cartridges contacts to fix this error code
§You should open the printer, wait for the carriage to slide over. Then remove the ink cartridges and clean the print head with cotton swabs dipped in hot water. Once it is finished, allow to dry the print head and replace the cartridges.
If you still stuck then do visit this site: Canon Support Code 300
Toll-Free No: +1-888-633-7151
Posted on Aug 09, 2019
Ron Reynolds
    Master:
  • 433 Answers
Check on the Canon website under support. Enter your printer model number and the error code.
Posted on Dec 15, 2017
5 Related Answers
Anonymous
  • 49 Answers
SOURCE: canon pixma mp610 - error 5110
Take it back and exchange it
Posted on Jul 05, 2008
TIPS72
DUSHYANT SINGH
  • 369 Answers
SOURCE: Canon MP610 - Paper jam error message
PLEASE REMOVE THE POWER CABLE AND REINSERT IT IT SHOUL BE OK AND IF STILL PERSIST JUST RESTART THE PC IF STILL RESIST PLEASE LET SOME TECHNICIAN TO CHECK FOR THE SENSOR FOR THE PAPER JAM ...
GOOD LUCK
Posted on Jan 04, 2009
komguy
Craig Gillette
  • 2306 Answers
SOURCE: CANON PRINTER MP610 ERROR
That's a purge drive error, indicates you need a new purge assembly, the part that cleans and prime the printhead, on the right side. It could also have a paper scrap or something blocking it's operation.
Posted on Aug 25, 2009
Anonymous
  • 51 Answers
SOURCE: My canon MP610 shows an error message U052 Incorrect print head
http://www.buzzillions.com/review/canon-pixma-mp610-multifunction-photo-printer-review-2458903?prRo=0&reviewSortBy=mostHelpfulFirst&prRpp=1
you wont like what you find. lol .
apparently if you call cannon support they going to tell you its a U052 is a temperature sensor error. and not the print head error. someone musta did some bad programming. lol
try returning the cartridge if its not a canon specific cartridge - and get replacement - try that - but i doubt its going to work - i would call about a new one (print head that is - they will also apparently send you a new print head.) as i have read up on
hope this helped x404x
Posted on Mar 01, 2010
Testimonial: "Thanks for your quick response - I thought there was a resetting tool available so I can at least remove the message and get printer going."
Anonymous
  • 84 Answers
SOURCE: My Canon Pixma MP610 won't power up. I've
You've eliminated all other options, so obviously your printer is defective.
Call canon if it is under warranty, otherwise you will have to replace it.
Posted on Apr 08, 2010
Canon pixma mp610 cant delete the printing queue or print
This is not the fault of the printer but windows. Open the Control Panel, select Devices & Printers, find your printer, click on it, select Delete Print Queue. Problem is fixed.
Jan 07, 2013 | Canon PIXMA MP610 InkJet Printer
Service error 5C00. Cancel printing and turn the printer off and then back on. If this doesn't clear the error, see the printer manual for more detail.
Waste Ink Counter Reset.
(1) Turn off the printer.
(2) Press and hold the RESUME button, then press and hold the POWER button.
(3) Release the RESUME button, Next press and release the RESUME button two(2) more times in succession. Note: you are still holding the POWER button). The printer's carriage will “reset" or move momentarily.
If the above was properly performed the printer will enter the "Service Mode".
(4) Press the RESUME button 4 times, this will select the clear waste ink counter function. The lamp will alternate (change) color with each key press. Next press the POWER button to "set" the change, and return to the top of the function selection menu. Press the POWER button again to restart the printer.
The problem with resetting the waste ink counter is that the waste tank could at some point over-flow. If you manage to get inside to empty the wadding and waste ink tank, make sure you wear rubber gloves as the ink will get everywhere..
And make sure you replace with some fresh wadding if you can..
Regards
Mike
May 27, 2010 | Canon BubbleJet i560 InkJet Printer
Canon i9950, Operator error,5 amber blinks
  1. Turn off Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Jan 02, 2010 | Canon i9950 InkJet Printer
THE INK ABSORBER IS ALMOST FULL
Canon iP4500 waste ink reset:
1) With the machine power turned off, while pressing the Resume/Cancel button, press and hold the ON/OFF button. (DO NOT release the buttons). The Power LED lights in green to indicate that a function is selectable.
2) While holding the ON/OFF button, release the Resume/Cancel button. (DO NOT release the ON/OFF button.)
3) While holding the ON/OFF button, press the Resume/Cancel button 2 times, and then release both the ON/OFF and Resume/Cancel buttons.
4) When the Power LED lights in green press the Resume/Cancel button 4 times
then press the ON/OFF button.
I found this info by googling iP4500 waste ink reset. It is the same procedure shown in the service manual for the iP4200 and the MP610. In the MP610 service manual it says after the reset it will print a page: ("D=000.0" is printed at the top left of the paper.) I don't know if the iP4500 does this page print, so you might want to have at least one sheet of paper loaded just in case.
Nov 12, 2009 | Canon iP4500 Photo Printer
Canon 19900 printing fine then refuses to print showing error 300
1) With the printer powered off, hold down the resume button and press the power button.
2) While holding down the power button, release the resume button and press the resume button twice in succession. Now release the power
button. The indicator will blink in green and remain lit in green.
3) Press resume 4 times (Green) for Waste ink counter reset.
4) Press the power button. The printer will switch itself off after performing the function.
Or try
1) Power off printer
2) Hold RESUME button then press and hold POWER. (The beeper MAY sound once, or may not depending on your model.)
3) Hold POWER and Release RESUME.
4) Press RESUME twice then release both POWER and RESUME buttons.
5) When the indicator lights steady, press RESUME 4 times (for the S900, 3 times for the 8200 apparently).
6) Press power to set data.
7) Print away!
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Sep 16, 2009 | Canon i9900 InkJet Photo Printer
Inner cover of printer MP610 -error 'inner cover not closed'
I am still on . Get back if your problem is not solved.
Aug 03, 2009 | Canon PIXMA MP610 InkJet Printer
Canon PIXMA MP145 blinking power LED and alarm LED.Displays E...2....7.please assist me
E27 means waste ink absorbed is full need to clear out but you still can't print because only 80% or 70% are full.try this method to solve you problem.
Resetting Printer Canon MP140, MP160, MP180, MP210, MP220, MP460, MP470, MP500, MP510, MP530, MP600, MP610, MP800, MP820, MP810, MP830, MP960, MP970 procedure:
•Turn off the canon printer
•Hold the Resume Button (red circle in the triangle), add a printer (click “Power”) an indicator light green.
•Hold the Power Button, release the Resume Button.•Not releasing the Power Button, double click “Resume” and release Both Buttons.after that wait the green flash will become light on then.
•Click “Resume” for Four times
•Once you click “Power”, to confirm the selected action (reset counter absorber). To disable the printer “Power” button to click again.
if this ok so u can print or can't. i still suggestion you bring you printer to computer shop for clear out inside spam printer.
Aug 01, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon MP610 ink refill
Without the resetter it will continue to give error codes, holding the resume button for 5-10 seconds sometimes will turn off ink level reporting, but you either need the resetter or to purchase and install reset circuit boards on each cartridge you refill.
Jun 18, 2009 | Canon MP610 Photo All-In-One Printer
Operator Error Canon i850 printer
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i850)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Dec 09, 2008 | Canon BubbleJet i560 InkJet Printer
Status Monitor informs of Ink levels requiring me to press resume button during and after each print job.
What it means is the tank to collect waste ink (from cleaning etc) is full.
Canon suggest you return ther printer for replacement of the absorbant mat, suggest you scour the web for DIY cures.
Oct 19, 2007 | Canon i9100 InkJet Photo Printer
Canon MP610 Photo All-In-One Printer Logo
88 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
CheckitRight
CheckitRight
