SOURCE: Where is the fuel pump
Hi!!
The fuel pump relay is integral to the Central Junction Box ( CJB ) and is not serviceable
Applies to, but not limited to the following models:
Expedition / Navigator -- 2003 - 2006
Excursion -- 2002 - 2005
F-Super Duty 250-550 -- 2002 - 2007
Good Day!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
SOURCE: where is the fuel pump relay located in a 2003
in the underhood fuse box just beside the master cylinder the fuel pump relay location number is 50B, in the same box also check fuse # 23
A 20 Amp Mini fuse for fuel pump power
SOURCE: On a 97 F250. Where is the fuel pump relay located?
it should be the small green relay that is on the inner passenger side fender
SOURCE: location of fuel pump relay on e-450 v-10?
The Fuel pump relay is in the Power Distribution Box under the hood, it is relay K. If it is the fuse then fuse 17 in the PDB.
It could also be the cut off switch, which is either under the dash above the brake pedal or behind the passenger kick panel
SOURCE: 1988 ford f150 fuel pump relay location
inner driver side fender well along with the eec relay
