Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Fisher & paykel mw511 pride
G,day, the machine works fine on the wash cycle ,but when it hits the rinse cycle it usally stops half way through and never reaches the spin cycle on its own. we turn the plug off on the wall and restart it and 50% of the time that will work, it appears to be pumping out the water ok, but it will still stop 5 or 6 times through the rinse to spin cycles. i was leaning towards the motor controler is stuffed. any ideas would be great , thanks in advance. rick plane
Posted by rjj1701 on
Peter
    Champion:
  • Fisher and P... Expert
  • 203 Answers
When it stops it should be beeping and showing an error code. When it beeps and before pressing any buttons look at the top row of 8 lights. Count from the right and tell us which number lights are on and which are off. If it is stopping and not beeping then I would suspect a faulty control board. Give us an error code to work with.
Posted on Jun 17, 2017
Paul Chapman
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 147 Answers
Check the pipes actually work first. Is there a hidden drain filter that is partially blocked? Dissasemble the pump and check it works and the blades inside are clean.
Posted on Jun 13, 2017
5 Related Answers
JULIANFIX
ALBERT GARCIA
  • 975 Answers
SOURCE: fisher & paykel (mw511)
check out the DRAIN MOTOR PUMP , its a small motor with 2 hoses connected to it , it could be clogged , need to remove it , inspect inside the impellers for any debri , clean it , re install and try again , hope this helpful AJ
Posted on May 20, 2008
l blight
  • 28 Answers
SOURCE: Fisher and Paykal GWL 10 US - Stops before rinse
52. (00110100) Eco - Diverter Top-up Fault diverter valve made be stuck in half open position ,may be a mechanical obstuction or the wax filled solenoid that actuates it may be faulty .located under machine beside pump .
Posted on Jun 17, 2008
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: Fisher & Paykel washing machine wont turn on
It appears your timer has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
HansPP
Hans Pearson
  • 2510 Answers
SOURCE: fisher and paykel mw511 washes
If it smells during the spin cycle the belt could be slipping and burning in the pulley. You may need to replace the belt.
Posted on Feb 08, 2011
Anonymous
  • 6277 Answers
SOURCE: Fisher and Paykel Pride MW511 does not spin. Three
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is normally behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Feb 19, 2011
1helpful
2answers
Why won't my Fisher & Paykel washing machine complete its cycle?
it appears to be a control module problem
have it checked by an authorised F&P technician
Fisher paykel mw511
take it apart-something has let go in the tub suspension department-springs or bearing-tear it down and it will become apparent-cheers Denny
Washing Machine F&P MW511. Washed, then rinsed using the fabric softener, partially spun then stopped. Will not turn on at all now (no power)
Hmmmmm - I think you may actually have a faulty controller module - without a working module it generally means no power on etc for Smartdrive washers..
2answers
Stops half way through rinse cycle and beeps
Best off to call a certified repair company such as Sears.
2helpful
My MW511 model is not spinning , slow motion wash cycles, noisy
Hi blow down the hose that the waste water comes out of, it may be blocked
Fisher paykel washer
Sounds like you could need a new out of balance switch or bracket, also try to make the clothes evenly spread in washing machine on rinse if they clump up on one side of the bowl they will cause out of balance :)
5helpful
2answers
Fisher and Paykel Pride 5.5kg washing machine, everything works fine until you get to the spin cycle and then it just beeps and won't do anything more. What can I do to check or fix this?
My washing machine will not cut off on a high water level, but will on the medium. It will wash until it gets to the short wash and then it just beeps at me. I tried to advance it to the rinse cycle but the light just blinks and won't do anything more. It did drain the water out though. What's the problem and how do I fix it.
Washing Machines Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
