We have just installed our new fridge. We ended up bypassing the filter as the water just trickles out if we use the filter but is good with normal water supply. Only the water isn't chilled, the fridge rattles quite loudly and we had to wriggle the motor to stop this! Kind of over the whole thing! Why isn't the water cold?
We bought one of these based on Choice mag review. Big mistake. Cold water dispencer dispences room temp water and ice maker makes ice at a snales pace. DO NOT BUY ONE OF THESE.
Try this link.. Fisher and Paykel E522BRXFDU Water from dispenser is not cold Google Search ..
or this link..
Did you let water run through dispenser long enough for air to get out of lines and for reservoir to completely fill?
SOURCE: Ice maker stopped
is the ice collection bin in the correct position? Is the icon displayed on the control panel to indicate the ice maker is on?
I hope this helps,
SOURCE: Our E522B Fisher & Paykel fridge no longer making ice?
Try the video on checking the F&P icemaker.
www.appliancehelponline.com/servicemanual.html
SOURCE: Our E522B Fisher & Paykel fridge is less than
Try the video on the F&&P icemaker it will walk you thru diagnosing the problem. www.appliancehelponline.com/servicemanual.html
SOURCE: E522B bottom freezer Ice maker not working. Red
the ice is just freezing in the bottom of the bin in a solid mass
SOURCE: Just purchased this fridge and the motor appears
Normally all what is heard is HUM which needs one to listen. Hiowever is you experience a high noise then being a priviledge customer you need to get a consensus to your viewpoint as the fridge is covered with warranty.
Please check for SYMPATHETIC vibrations on the rear panel due to loose fitting which can happen with transportation.
Your observation is most important.
Thank you for using fixya.
