I checke the battery to see if that was the issue even i tried jump start it but nothing happens and would like to know where is the back up battery fuse located that might be the problem.... I guesss
SOURCE: 1994 Toyota Tercel Starter Problems
sounds to me that you have an igniton problem not a starter problem and or if you have or had an alarm system could be cause if u do give me feedback and i will explain but seems that your starter is fine from what u say but if you think in terms of the elemts to start a vehicle batery gives pwoer to ignition which sends to starter which gives spark etc i would check you ignition system something is causeing a short and not alowing starter to function
SOURCE: 1989 Subaru Gl Wagon At
does the vehicle have an alarm system??? possiblly causing fault, or if the battery is fine, check the main fuse in fuse box located in the engine bay beside the battery,
SOURCE: 95 Mazda 626 won't start Y?
sounds like the starter, i dont think its siezed the motor in that short distance. try and hit the starter with a hammer or something with someone turning the key at the same time, it should start with acouple trys. if it does than u need a new starter.
SOURCE: 1981 vw diesel pickup,ignition switch problem?
Make sure to check all of the connections from your battery to the starter and especially check the ground and the body to engine ground.
This is usually the problem.
Thanks,
Tim
