I am useing BSNL BROADBAND NOKIA SIEMENS NETWORKS residential router 1600 with one pc now i wish to connect with another pc at another room , i set a cable but connection is not made with the other one but the oler one is connected now what i have to do to connect with the other pc ?
SOURCE: adding another computer to a linksys wireless G router using cable
The message "a network cable is unplugged" indicates that the networking cable was removed or not connected properly either at the back of your PC or at the Ethernet port of the router. Perhaps you can remove and re-insert back and please verify that you hear a click when inserted right. At times, the cable itself maybe at fault, pls replace if necessary.
It is not necessary to install the router software on the new machine or tweak any settings if your new machine is set to auto obtain network configuration.
Hope that this be of some help/idea. Pls post back how things worked out or should you need additional information.
good luck and kind regards.
SOURCE: router and pc configuration to connect broadband via dsl modem
Sorry i tried to open 192.168.0.50 and it could not display. what is the new IP
SOURCE: unable to connect with dlink300 router
You must configure first its settings both on your network card and router. See you manual.
First you must connect your internet directly to the computer then get its DNS settings, jot it down. Then connect the router lanport1 to lan card port of your computer using LAN cable. Under lan properties goto TCP/IP settings input the default IPaddress 192.168.0.1 of the router then its subnet mask commonly 255.255.255.0, the router's default gateway, input the DNS settings of your ISP 2 of the set.
Then goto default router's utility web. Open internet explorer, key in router's ip add 192.168.0.1 you should go to router's configuration log in user = admin, pass = just hit enter. Set your time and date then save. You could also test its connection by pinging the IP address of router. on windows DOS. Type ping 192.168.0.1 you should get 4 lines.
If everything is set. Connect the internet cable(UTP/LAN cable) to its WAN port of the router then test to browse the internet. If not then change the DNS settings with the remaining set (on Lan setting).
If I miss something just leave a comment.
SOURCE: DIR-300 router and broadband ISP connection,is NAT possible?
With a cable broadband connection, the cable line comes into the cable modem. The cable modem does the work changing the cable signal to a network connection and sends an I.P. address to the computer. With some cable internet providers you can hook the network cable into the in port on a router, wireless or wired, then hook up computers to the router. At this point the router gets the IP from cable and uses it's own IP routing for your internal network. Some broadband providers control your access by the computers mac address which registers with the vendor. If this is the case then the easy way to make it work is to get a router which can clone a mac address so the vendor still sees the same mac address.
SOURCE: I want to port forward my router it is Nokia
> 100 Kb/second [using] browser
Web-servers, such as the one hosting 'www.HowToTell.com',
are designed to give fast download speeds.
> BitTorrent ... 2-3Kb/second
When you are downloading, you are connecting to other people's "home" computers. Typically, their ISPs (Internet Service Providers) limit the speed of "uploading" (going "out" from those home computers) to a value about 1/8 of the "downloading" (going "into" those home computers) speed. That is "Strike One".
So, if multiple BitTorrent users are simultaneously "leeching" some files from the _same_ home-computer, that computer's speed-per-user is going to be very limited. That is "Strike Two".
Also, BitTorrent has been programmed to discourage "leechers" -- those who download to their computers, but who do not offer to "share" any content. So, being "behind" a router, your computer is being "blocked" from allowing people to "upload" (from your computer) and download (into their computer) any content. That is "Strike Three".
Login to the web-server on your router, and enable and configure "port-forwarding", to allow others (including the "Copyright Police" who monitor BitTorrent for violation of copyright law) to access your computer. (Violate copyright, and pay a big fine, and maybe go to jail.)
Testimonial: "Thanks for ur advice. But it is not possible for me to increase speed because my router does not have port forwarding function. Anyway Thanks,"
