Sounds like a winding, grinding noise when steering vehicle to the left on curves at any speed and no noise when steering to the right. I changed left wheel bearing only.
Looks like it's time for a right wheel bearing, or however many there are in the hub. I'm assuming you do not have a 4 wheel drive. Remember, if it makes noise when turning left, you are "loading" the right wheel bearing. ( Shifting more weight to the side inside your turn). Think this way. When turning left at a higher speed, the left tire might even come up off the ground! That puts all the weight on the right. If you've 4 wheel drive, could also be c.v. joints, or universal joints.
SOURCE: grinding noise in front wheel just changed pads not pads
sound like front wheel bearings badly worn.
SOURCE: steering wheel make a noise when turn left
its due to low/no fluid level in the power steering reservoir.Check the fluid in the power steering. If it is low the car will make noise when you turn the wheel. the internal parts gets rubbed hard and noise occurs. refill the fluid and let it reset for some time then try it will get the fluency to move smooth and noise will get stopped.
This will help. Thanks please keep updated.please do rate the solution
if helped.thank you for using fixya.
SOURCE: noise in front end, sounds
You say the rear wheel axles and bearings have been replaced, you mention nothing of the front wheels, you have the symptoms of a front wheel bearing being worn out, remove them and check for pitting in the bearing rollers or the bearing races, I am sure you will find a problem. Hope this helps solve your issue with the bearing noise.
