Question about Motorola Mobility Radio Communications
I need to disable the BT Headset ringing
like the topic says i need to disable my total annoying buildin ringtone on my Jabra BT 2020 Headset. My Phone is a HTC Touch Cruise.
I tryed to change the Ringtone but it isn't possible, so if found a way to stream the Phone's ringtone to my HS. But the Problem is that when someone calls the Headset still plays its own ringtone and is blocking all audio from my Phone.
Is it possible to change the Phone setting so it never notifies the HS it should ring? ^^
That would be perfect.
I hope someone knows a way how to do that.
p.s. sorry if my english isnt clear
-Diver
Posted by XDiverX on
5 Related Answers
Anonymous
  • 944 Answers
SOURCE: Incoming caller ring
Here is the link to the user manual if you need it. http://www.motorola.com/Hellomoto/Master%20Lists/Product%20Manuals/Static%20Files/CA-EN/30277_E815EnglishUserGuide.pdf Unfortunately what callers hear is dependent on the phone they are calling from, not on your phone. You could concievably send them a mutimedia message when they call, but there is no way to automate this, and it would probably be too much trouble and expense to bother. Wait a year or two, and it may well be that manufacturers start including this feature - it would require a slight modification of the communications protocols on the cell networks, but it probably would be popular. Good idea. Hope this helps :)
Posted on Jul 10, 2007
Anonymous
  • 316 Answers
SOURCE: problem with the number of rings
Remove the voicemail or extend ring time
don.t know is this code works world wide but you can try otherwise ask the provider to lengthen the ring time to 30 secs
then enter country code IE 61 for australia
* then vmail number IE 321 for optus
**30#
so your code should look something like this
**61*321**30#
then hit call.
remember the 61 and the 321 will vary on country and provider
Posted on Nov 09, 2007
Anonymous
SOURCE: 6600 ringtone
go to Profile in Menu
select outdoor
options- personalise
set to------
Ringing Tone-  any ringtone u want
Ringing Type- Ringing
Ringing Volume- Full
Message Alert tone- any tone u want
Vibrating Alert- on
keypad Tones-__________
Warning Tones-_____________
Alert For-_________________
Profile Name-_____________
Posted on Mar 27, 2008
Anonymous
SOURCE: problem with the ringtone in HTC
Then you deleted it from your ringtones in the file explorer.
Posted on Mar 21, 2009
Anonymous
SOURCE: ringtone will not work
Even though I've reset the master volume, etc. the ringtones will not work, I can't play them and the phone will not ring. In tools, sounds setting, call sounds, call ringtone: help
Posted on May 12, 2009
Hi . Where to purchase ear gels for a Jabra BT 2080 headset. thanks.
You can purchase ear gels for a Jabra BT 2080 headset from " http://shop.ebay.com/i.html?_nkw=jabra+bt2080+ear+gel".
Good Luck.
Hi, i have just set my JABRA BT 2070 however i accidently clicked on LETS FORGET this and now my jabra bt2070 is not pairing ny longer, please help
1. Switch Bluetooth headset off. 2. Press and hold the answer/end button until a solid blue light comes on. Headset in pairing mode. 3. Go into phone's bluetooth options and "search/look" for devices. you should see the headset. 4.Pass code is "0000"
should connect and be good :)
hope this helps
I have 2630 nokia phone i use my jabra bt 2070 for this one and then i bought a new phone 6120 nokia but i cant use the headset on it every time i search for jabra device my phone cant find it
First turn ON your bluetooth on phone, then hold on/off button to turn ON Jabra headset for 5 SECONDS, then vill light hold ON (NO BLINKING) and then find it on your mobile phone....
Hi from Serbia ;)
Jabra BT 2020 bluetooth cannot find a new phone
These must be set to learning mode to find any device. Hold the power button down for 8 seconds until the light comes on and stays on, then it is in learning mode and should find your phone
Jabra BT620s pairs to laptop but unable to switch sound output.
I had this same problem with my sony vaio (vista). But at first for me, after BT enabled the device, I couldnt find it in the device manager. I cycled on and off the headset a couple of times and once my vaio began to automatically connect the device, I was able to locate it in the device manager. Next, I went through the contol panel, hardware/sound, "manage audio devices". Here the bluetooth headset was located. After sucessfully testing the headset, I set it to default. Now whenever I fire up the headset, I have total mobile sound...awesome
2answers
Jabra A7010 BT hub will not pair with Sprint BT headset
Have you tired to pair your hub with any other non-Jabra headset? I am trying with Plantronics Voyager 520 without success ;(
Jabra bt 160
how to connect jabra bt 160 to nokia 7610
8helpful
Unable to Detect the Jabra BT125 headset from any Bluetooth Device
If you hold down the button, it will turn the light blue, keep holding it till you can connect it. It will come up as Jabra BT125, hit connect. Then it will ask for a password. The password is 0000. Then it will connect :)
1helpful
Bluetooth from Samsung D900 (HELP PLEASE!)
nback - DO AHARD RESET *2767*3855#
KEWL - BUT YOUR BT TO SEARCH SWTCH THE JABRA ON THEN PAIR THE P/W 0000
Radio Communications Logo
Top Motorola Mobility Radio Communications Experts
Willie Mondo
Willie Mondo
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
