Question about LeapFrog My Pal Violet
Installing leapfrog my pal violet on windows 8
Im trying to install mypal violet on to my windows 8 laptop (only pc in the house) and its telling me that adobe flash isn't installed on my computer but when I go to the adobe site where it directs me it tells me that it is installed :S Any help would be greatly appreciated.
Posted by distrubed948 on
3 Related Answers
Erin RMS
  • 8 Answers
SOURCE: Brand new leapfrog pal violet... installed
This might be a dumb question, but does it need new batteries?
Posted on Mar 30, 2011
Erin RMS
  • 8 Answers
SOURCE: my dauhter got the leapfrog
You have to download the software for your computer that allows you to connect Violet in order to change the name, etc. Once you do that, connect Violet with the cable included and follow the steps. If you need more help let me know. It's a little tricky sometimes if you don't do things in the precise order.
backk
SOURCE: I'm using Windows 7 64-bit.
I am having the same problem, contacted Tag (who is only there during work hours which really does not help) they supplied me with an alt connect file. That did not work either. Have you found a solution yet?
Kat
Posted on Jun 21, 2011
My pal scout won't download from leapfrog connect it says error 400
I put in a new set of batteries and the data synced/downloaded to scout.
Mar 04, 2014 | LeapFrog My Pal Violet
Violet wont turn on
One thing to check, especially if you are replacing batteries, is for corrosion on the terminals. I just replaced batteries in my daughter's Violet, and it wasn't working. When I looked closer, I found a couple of the terminal contacts had corrosion (looks like rust). I took a few Q-Tips with some white vinegar to clean them up until I could see metal on the contacts again. After putting the batteries back in, it worked fine.
Feb 18, 2014 | LeapFrog My Pal Violet
Information won't save to Violet
My experience is that after charging for some tens of minutes it will start. But I seem to be unable to charge the battery enough to have it work for long.
Feb 08, 2013 | LeapFrog My Pal Violet
I have a LeapFrog My Pal Violet (and Scout). The have been personalized with my child's name and favorite "things". My question is: How do I reset or clear this personalized information...
Here you are. It took a while to find the instructions!
In addition, if you would like to delete the data on your device prior to recycling, open the LeapFrog Connect program, sync your device via USB to your computer, click on the product you would like to reset from the "My Products" screen, then under "Settings," select "Reset". If you have not downloaded LeapFrog Connect, please follow these instructions to do so.
eWaste
Aug 26, 2011 | LeapFrog My Pal Violet
My granddog grabbed Scout and now Scout only plays one song. The toy wasn't ripped or even a hole. Can Scout be reprogrammed? When you push the pads it trys to play something else then goes back to the...
There is a possiblity that the ciructs inside could ahve been damaged but you could try reprogramming.
To reprogramme violet you will need to install the leapfrog connect software which you can download here (Windows) or here (Mac). Then follow the instructions in this PDF
Hope this helps
Mar 06, 2011 | LeapFrog My Puppy Pal Violet
How to clean violet the dog
We have a Violet and she in need of a bath. I took the voice box out of her and
found that her wires are not removable from the voice box. You have two
choices here. Rent/buy a steam cleaner or buy a new one and program it. I am
very frugal and will resort to rebuilding something myself if I can save a buck.
Short of getting a sodering iron involed (which I might do) those are your only
options.
Jan 09, 2011 | LeapFrog My Pal Violet
My dauhter got the leapfrog my pal violet dog for christmas before receiving this my brother programmed in my daughters name and colour ect i want to change and add info myself but when connect the toy...
Dec 29, 2010 | LeapFrog My Pal Violet
I just purchased my 2nd Asus My Pal A626 Pocket PC. And I cannot run the setup program on any of my 5 computers. It tells me I need Flash 8.x or higher and I have Flash 10.x or it says I may have a...
Go to a command prompt (CMD) by navigatinf to START->RUN and typing CMD In the command prompt, type Type c:\Program Files\Common Files\InstallShield\Driver\8\Intel 32\IDriver.exe -Embedding Then run your setup.exe or install.exe of the prog you are trying to install...
If this doesnt run, think there must virus infection in all your system...
Does any other setup files runs in your system?
Please leave these details as comment and we will provide further assistance
Rnj VINODKUMAR
Nov 03, 2009 | ASUS MyPal A626
LeapFrog My Pal Violet Logo
410 people viewed this question
Top LeapFrog Toys Experts
Nikki  Mclean
Nikki Mclean
Crystal Walters
Crystal Walters
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
