SOURCE: Heated seat AND driver's side door lock doesn't work
no connection of the two, start by checking switch for heated seat, if power is there and switch is good then heating element is probaly bad,the lock could be linkage jam or lock acuator, good luck.
SOURCE: 2003 Volkswagen Jetta Seatbelt is sticking
Have you tried pulling it out real slow.. Also make sure car is stopped when putting it on.. Any fast forward movement locks the belt.. hope this helps
SOURCE: Driver's side door power locks are stuck; door stuck shut.
sounds like the rods are disconnected the clips hold the rods in place the latching mechanism holds the handle in place as well did you replace the speakers or did a shop? if a shop did then they caused this if you did then you may have caused this either way untill you reattach the rods none of it will work. you will have to manually open the door at the latch from inside teh door behind the panel.
SOURCE: 1998 Toyota Corolla Electric Door Lock Problem
You'll need to replace the solenoid (motor) that doesn't work. Not hard once you get the door panel off. I suggest you buy the correct part, not a universal one.
SOURCE: front door speakers
i found the service buliton on this problem straight from GMC, bulletin No. 07-08-44-008 this is a recall issue and you need to go to the dealer to have them resolve.. i was locked out of your other question please rate this with the other one you have up... thank you Dave
