Horn does not work. Have replaced horn relay & fuse and it still isn't working. Please advise
SOURCE: My 1999 Plymouth Breeze has the horn on all the
it is in the clock spring behind steering wheel contacts are broke completing circuit and making horn work
SOURCE: 1992 plymouth voyager horn does not work
there will be a relay in the fuse relay box under the hood
SOURCE: 1997 Neon Horn Will Not Work
Did you look up under front facia in front of radiator, in center support area? I wouldn't be pulling wheel until I found horn first. Make sure you disconnect battery before, if you do.
SOURCE: 1998 Grand Voyager horn not
You can check the clock spring. Remove the cover over the stealing wheel where the emergency flasher is. At the bottom there are two connector side by side. the small one on the left is for the Air Bag, the one on the right (6-7 pin connector) is for the horn and cruise control if you have one. Disconnect the right connector. Us a wire to gound out the pin in the lelft side of the 6-7 pin connector. If the horn sounds, then it is either the clock spring or the air bad itself that needs to be replaced. I would bet it is the clock spring.
