Cars & Trucks Logo
Posted on Jan 01, 2013
We're is fuse for brake lights? I don't have a owners manual to look at its a ba falcon
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 01, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
843
Points
Google ba falcon fuse diagram & click on the images. I thought the images weren't clear but when you click on them they are. Hope this helps!
5 Related Answers
Anonymous
  • 191 Answers
  • Posted on Dec 28, 2009
SOURCE: Have BA Ford Falcon with tail lights that are
sounds as though the brake light switch is stuck it's down behind the brake pedal arm try removing it and cleaning around the plunger where it goes into the switch also look at and see if the plunger has became bent from years of use you may need to just replace the switch.
zestar
zestar
  • 6 Answers
  • Posted on Mar 13, 2010
SOURCE: have 2005 BA MK11 shockwave blue falcon,paint
You may want to reference the Ford Australian Forum Boards.
There has been active discussion on owners being compensated
for particular model years due to a fault with the Shockwave paint.
On a separate note, the auto industry uses our technology for paint durability measurements (film thickness).
We have issued two press releases and have contacted Ford Senior Management on the impact of outsourcing paint applications process and quality control to the Paint Suppliers.
Press Release 1
New Books Reveal Vehicle Paint Quality Flaws Associated with Outsourcing
Press Release 2
Billions Discovered for Recovery by Automakers
We have released two books -
Basic Guide - For the Consumer
Technical Guide - For The Automaker and Auto Dealer
"MAKING IT RIGHT'
Why your Car Payments
are lasting longer than your
FACTORY PAINT JOB
We do have research data on various automakers vehicle models from the factory which shows they were released to the automaker, auto dealer and consumer below Ford's paint thickness specifications.
Low film thickness results in paint peeling, stone chipping and body rusting.
Paint applied too thick will crack.
We are advocating a "Truth in Finish Disclosure" to protect automakers, auto dealers and consumers.
You may want to advise your auto dealer on the book and do a search inside the book on either Amazon or our website for additional information.
Anonymous
  • Posted on May 01, 2010
SOURCE: ba falcon heater
Just had the same thing happen to my BA. No hot air. I'm a bit of a handyman so I had a go myself. 8 Hours is a reasonable estimate. You have to remove the steering column and entire dashboard to get the bugger out. Not a job I would attempt again.
KimSland
  • 58 Answers
  • Posted on May 15, 2011
SOURCE: BA Falcon 'door open' light is on, can't lock
Hi I have the same problem on my BA XT Falcon
Strangely it only happens after it's rained on my car (usually overnight) I then notice that the drivers lock is up and will not lock again until a nice sunny day comes and I leave all doors wide open for hours and hours!! Then all of a sudden once closing all doors normally the little dash door light turns off, and I can again lock the doors
Since it rained all last night here, guess what? It happened again!
So I've checked everywhere and cleaned and you name it, but nothing, I'm positive that when a warm sunny day comes again though, all will be ok.
Most annoying issue ever.
Where is this tiny bit of water that's causing this?
And which door?? Can I just disconnect one door at a time? I don't know it's driving me crazy!!!!
Anonymous
  • 720 Answers
  • Posted on Jun 07, 2011
SOURCE: brake light switch on ba
If you refer to the following BA Falcon pedalbox diagram, it shows the Brake Lamp Switch (No.10) is on the same bracket, below the Cruise Control Cut-off switch (No.11 - if cruise is fitted).
Study how the Cruise switch is mounted to the bracket - the Brake Lamp switch should be mounted the same way.
From the diagram, it looks as if both switches can be ROTATED to remove from the bracket (ie turned until the switch can drop through the bracket). Study the photos carefully.
If for some reason the switch requires a new mounting clip, then contact Ford to see if you can purchase the clip by itself.
If Ford only sell the switch as a complete unit, then start ringing your local Ford wreckers/dismantlers to compare their price for a 2nd hand Brake Lamp switch.
Cheers,
"If this has helped you, please rate this solution with thumbs up or kindly leave a testimonial"
Need fuse diagram for ba?
Howdy howdy John Mullins,
Thanks for adding the 2003 CLUE... that verified what I was suspecting: I am guessing the "BA" FORD nomenclature is pretty obscure ... I had to LOOK that part up... also "Utes"... Cute!
Now I am understanding "BA" to be a series of "Falcon" Fords
indigenous to DOWN UNDER typically between 2002 and 2005
(or 2003 to 2008... else where on the internet).
Being a life long FORD owner... I can tell you for certain FORD Factory manuals were/are available from the dealers... Being old fashioned... I like the hard copies (and have too many cars not to be self reliant)... and they all have the wiring diagrams, circuit drawings... schematics FOR SURE (Volume 3 of 3 on my '04 Navigator & Volume 3 of 5 on my '75 Ranchero).
You are going to like the last (Cabulture AU, local) option the best... eBay.
Ford Falcon BA
Ford LTD BA Service Manual Download pdf
http://manuals43.hobsonjuiceplus.com/manual-ba-ford-v8-2003-yskfqvy.pdf
2003 BA FORD workshop MANUALS
FORD FAIRLANE GHIA BA 2003 2005 WORKSHOP MANUAL All Manuals 12
1974 FORD CAR LINCOLN MERCURY TORINO RANCHERO OEM SERVICE SHOP REPAIR...
Only 1 out of 4 Brake Lights working
go to the given link and get the service and repair manual and fix the problem http://toolsnyou.com/
2helpful
We have a 99 Falcon Futura Au, we need a fuse diagram as it's not on the fuse case & we don't have a manual. We have a light on the dash that comes on when the car is started (fan in box
Probably will not get the fuse info here. I suggest you join up to the Australian Ford Forum. There will be someone there that can help you pinpoint the fuse you want and possibly scan the pages from the owner's manual for you with all the fuse diagrams and email the docs to you.
Here is the web site. Just register on the site and post you question in the correct area.
http://www.fordforums.com.au/
Warnimg brake light
What does the owners manual say the light is for ?
It won't go off until you diagnose & resolve or
repair why it is on.
When you ask a question we need lots of detail
We can't answer every question when a light comes
on & you don't provide a vehicle,engine & all the details
in the manual about the light & the vehicles driveability issues
I need to replace the back up light fuse... i do not have a owners manual
Helm.Com --- buy owners manual
Check all the fuses for now, till you
receive the manual
If you don't know where it is,you don't know
it is blown & if it is, replacing it won't fix a thing
2answers
I have a 1996 dakota with no tail lights. The brake lights work. I think it may be a fuse, but I don't have a manual to see what fuse it may be,????
Why would it be a fuse?
You have front parking lights? Then no fuse
If it was a fuse ---would that fix it -- NO it wouldn't
Why do fuses blow?
Have you even removed the tail light housing & checked the bulbs,
or checked the sockets for ground or under truck for wiring
harness issues?
Don't need a manual to check all fuses under the dash &
in the box near brake booster
1helpful
2answers
My windshield wipers, blinkers, and my emergency brake light fuses don't work. I don't know the number the number of the fuse to get to fix that.
Check underhood fuse box; can download your manual from this link: chrysler.com/en/owners/manuals (page 315 and next).
Hope this helps (remember to rate this answer).
3answers
2008 lincoln towncar fuse diagram. brake lights wont come on
ramundoo_10.gifhere is the schematic for the brake light circuit.don't rule out the mulifuntion switch.ramundoo
2helpful
2answers
I need a manual for a 2004 Ford Falcon BA Futura
Please kindly follow the link below to get the manual you requsted for;
http://fitripdf.com/books/ba-gt-ford-falcon-service-manual-2.html
thank you for using fixya
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
