Cars & Trucks Logo
A
Anonymous Posted on Jul 16, 2017
I purchased a used Jensen UV10 from a friend and installed it in a 97 eclipse spyder. I recently bought a 2003 chevy silverado 1500hd LX, and took out the aftermarket JVC cd player to install my Jensen. The JVC was working fine when I removed it, as was the Jensen. Upon installation in the chevy, it powers on and all functions work properly, except there is no sound. I've rewired several times and still the same outcome.
EdCarCal
Level 3:
  • Cars & Trucks Master 1,326 Answers
  • Posted on Jul 16, 2017
EdCarCal
Level 3:
Answers
1326
Questions
0
Helped
376591
Points
3749
Depending on the model, the Silverado may have an amplifier between the OEM radio and the speakers. If that is the case, you will have to remove it and wire directly to the speakers. Check the wiring schematics for the original truck radio option (one source is Alldatadiy.com).
1 Related Answer
Anonymous
  • 580 Answers
  • Posted on Jul 21, 2009
SOURCE: 2003 chevy silverado 1500HD LT. A/C fan works intermittently
First check fuses, then test blower motor, Last Temp control switch
1helpful
2003 silverado 1500hd steering wheel not locking when in park and key out just bought and did not notice this when I test drove thanks in advance
Yes, you will need a steering wheel puller and a lock plate tool. You can find them both cheap and good enough quality to use plenty of times. I got mine at Harbor Freight if I remember correctly. Tried doing lock plate one time w/out tool and it was a mistake. Gotta have tool.
I have a 2003 Chevy 1500hd Silverado and the reduce engine power comes up on dash and I lose all power after I turn off and on a couple of times and it works again whats is the problem and how I fix it....
try disconnecting the battery for 5 minutes to reset the complete system. a few different things cause the reduced power to activate, oil pressure, coolant temp, traction control. I use my snap-on MT2500 to locate these types of problems
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_4c166ba81493f541
2003 chevy silverado gear indicator lights don't work
Hi, this is a pretty common problem on these Silverado instrument clusters. We can definitely help you with that. Click here to learn more about these Silverado instrument cluster problems: Dr Speedometer Instrument Cluster Repair Speedometer Repair Guage...
1helpful
3answers
3helpful
2003 1500hd chevy silverado 6.0 liter. I had a
DTC Number
P0160 DTC Name O2 Sensor Circuit No Activity Detected Bank 2 Sensor DTC Number P0300 DTC Name Random/Multiple Cylinder Misfire Detected
1helpful
2helpful
2003 Chevy 1500HD 4x4
the problem is that your instrument cluster has a short circuit and it will need to be replaced you can try a used one but mileage will be off from yours you will have to remove the trim around the cluster then there are 4 screws holding cluster in place
1helpful
1helpful
In cold weather I get no oil pressure from the gauge,
You can Purchase a Built in Block Warmer for your Truck.
6helpful
2answers
Bad sensor on chevy truck
There are 2 both located in the block..
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
