Teac ct m685 shutting down
When powered on I get sound and a picture but after about a second the television shuts down
Daniel Moffat
    New Friend:
Removed and checked the power supply unit and confirmed the capacitors
C905 220uF 420V was measured at 200uF
C926 22uF 160V measured at 21.6 uF
C908 10 uF 100V measured at 10.35 uF
C910 47 uF 63V measured at 45.8 uF
Resoldered all of the joints on this PCB to ensure good connections.
On the Main PCB checked capacitors
C401 220uF 35V measured 214 uF
C417 100uF 160V measured 100 uF
C411 3300uF 35V measured 3090 uF
D204 was still a diode
C430 4.7nF 1600V measured 4.5 nF
C406 4700uF 25V measured 4460 uF
Reassembled and confirmed worked OK
These checks / repairs did fix this fault and the television is running well.
Posted on Dec 30, 2012
5 Related Answers
Anonymous
  • 68 Answers
SOURCE: Shuts Off Immediately
Does the TV shut off if a signal from the scart is selected? Philips sets have an annoying habit of going into standby after a very short time if there is no video for the synchronising circuits to lock onto. I find this a nuisance when I am searching for a signal from satelites when you move the dish. By quickly changing channels you are resetting the shut down circuit. This must be a time-out circuit controlled by a capacitor charging (I suspect) which has gone low in value, probably electrolytic. Replacing the capacitor should solve the problem.
Posted on Oct 17, 2006
Anonymous
  • 556 Answers
SOURCE: Panasonic CT-32HX42F Powers down by itself
it is due to plug or socket loose or sparking in that area. if it is ok then it is due to some component failure in power supply of tv. as per schematic is concern please go to. www.serviceinfo.com go in search & give model no.it is freely available.
Posted on Oct 06, 2007
Anonymous
  • 556 Answers
SOURCE: teac ct-m5100 colour television
http://www.remotes.com/
try this web site & get the reply.
Posted on Oct 19, 2007
Anonymous
  • 93 Answers
SOURCE: panasonic tv ct-32hxc14j
try to reheat or resolder your tv.
Posted on Oct 23, 2007
Anonymous
  • 1153 Answers
SOURCE: RCA Television D52W14
The first thing in this unit is to check the ribbon cable that goes from the front control panel to the back ssb board, I would unplug and replug to make sure seated properly. Then try it again. There are alot of screws to take out but worth it if this solves the problem.
Posted on Jan 08, 2008
Why does my Teac receiver only light up the volume knob, then shut right back off?
hi sounds like a fault in youre power supply circuit or there is a fault elsewhere causing the power supply to shut down .....u might need expert help .....good luck
My panasonic tau ct-34wx52 tv shut off by itself, now only clicks
Its power supply regulator section circuits need to to be troubleshooted.
1helpful
Spilled liquid on keyboard, need to remove keyboard to try and clean up spillage. cant remove keyboard because of the power button
if the computer is on, u cannot remove keyboard for safe purposes. u can press cpu power button for a long time till the computer shuts down. this shuts down the pc safely. after the pc shuts down remove the keyboard. u can either clean it or replace with new one.
About a week ago it started shutting off i could unplug and plug in again and it would work now i get sound and red screen for a few seconds then shuts off and power light blinks
this sounds like a bad picture tube as it is shutting down becausethey may be drawing too much current fairly common issue with these older projection tv sets
Once tv is turned on it stays on for about 2 min and shuts off. first the picture and the sound is still going then seconds later it shuts off and the lamp button blinks??/
Sounds like you have a problem that shuts down the Power Supply Unit, PSU, OR indeed more likely a faulty PSU.
In any event it is time for the repairman.
Teac CT-F683 whose picture is too wide
did u work it out ?? i have same problem and cant undo ??
My tv is working with sound and was fine. I shut
Your picture is missing- after 5 days call 911
Projection TV keeps shutting down
Good Day;
Sounds like you have a bad green picture tube that has failed. To check this out; remove front speaker grill, remove small panel, you will see three CRT's (pictue tubes) sticking down, remove the little board on the middle tube then restore power. If TV stays on more then likely the CRT is bad but not always the driver on board could also be bad, check voltages.
Good Luck, big IRISH.
No picture sound is fine
tv comes on then turns blue at that time it shuts down. The power is on and then it blinks 5 times!!!
TEAC CT-M685
This is a vertical-deflection problem. Try to adjust the vertical (height and linearity and hold) controls, which should be screwdriver potentiometer controls on the back of the set.
If this does not work, a defective component in the vertical-deflection circuit will need to be repaired.
I hope this helped you. :)
Televison & Video Logo
Top Televison & Video Experts
Ekse
