Microsoft Xbox 360 Wireless Controller Logo
Question about Microsoft Xbox 360 Wireless Controller
How to fix a xbox controller that spins after gettin wet
Posted by brianhannan7 on
Jeremy
    Master:
  • 350 Answers
After all is said and done, most likely since the capacitors were charged when it got wet its probably a lost cause to do a tear down and dry it.
Posted on Feb 20, 2015
Anonymous
  • 2,427 Answers
Hey Brian,, well you can try this..
1.) remove the battery from it,
2.) remove all the screws so the the control opens up,
3.) use a hair dryer, paper towels etc and dry it up as best as you could. use the hair dryer to finish of the job.
4.) re assemble and re connect the controller using the connect button.
Posted on Dec 29, 2012
Tl1000r wont start and plugs keep gettin wet
Is it sparking with known good spark plugs. If not you need iginition system diagnosis. If so you may have dirty injectors allowing them to leak or a bad fuel pressure regulator allowing too much fuel pressure causing the engine to flood.
The disc drive stopped working. it says Open Tray and then doesn't load the game
its either a motor problem, magnetic problem, or spin thing is gettin dry and needs to be lubricated.
3helpful
2answers
Xbox360 controllerjust keeps flashing and nothing else
You have to sync the controller. Push the sync button that is inline with or located right next to the memory card slots on the front of your XBox. When you push this button, the ring of lights will spin. At this time push the small button on the top of your controller and the Xbox Guide button light will spin as well. You are now synced.
If this somehow doesn't work, email me at
[email protected]
1helpful
Clothes come out wet
HI, this is a common issue that is easily fixed by, replacing the control unit. this control manages the motor functions during operations. if this unit is not spinning correctly, replace the Control unit. aka(motor control unit). In you washer, they call the motor control board a (Control Unit). replace this asap if possible. this will fix your washer. ADDITIONAL CHECKS--(Make sure that this unit is also draining water properly as well. this will cuase wet spin outs as well).
Guitar Hero Wireless
i reccomend gettin a new controll or press the little button on the top of the controller and then press the little button on the xbox
3answers
Won't load any game since new update
yeah i have the same poblem to i dont how to fix this... when i put the game disc to my xbox it says put xbox 360 console disc.. then when i return it to the menu it says play dvd...
Xbox 360 controller only looks up
Probably not if the internal electronics were damaged, but try resyncing your console with the controller before writing it off :-)
2answers
Controller failure
Maybe sync the controllers again? Press the guide button (with the logo) on the controller. Then press the little round button on top of the controller next to the left bumber and the light around the guide button will start spinning. Press the same little button on the console next to the second memory slot and the consoles guide button will spin and the two will link up.
does yours require batteries? replace them
Top Microsoft Video Game Consoles & Games Experts
David Shaub
Narseman
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
