TAke out the cartridge and unplug it and plug it back in and put the cartridge back in and see if thats the problem for you.
SOURCE: 543k toner sensor error
Your indication regarding the 100% does not necessarily indicate a damaged chip (sensor).
Many chips do not work by actually sensing the toner but by usage or other tricks.
We cannot be sure about what happened but replacing the drum and affected items
should solve the problem. Needed parts may be found at
http://www.inkfilling.com/toner-refill-OkiData--C5800Ldn.html
SOURCE: Check toner cartridge
Yes to non OEM's and those of you who are using them they cause heap em troubles.
It can be the drum they sit on, or toner dust on contacts of drums, machine base, and toner cart sides , also machine has eyes that get dusty, on machine frame at every toner/drum.
Pull out a tonerlook at side of handle there is a rectangle cut out silver/or black inside this lines up with "eyes" in side of printer frame, clean em.
I have also found a lot of import oki toners going around causing grief too, but fix is always sucessfull by A new gen non import toner and drum and ensuring contacts are free from toner dust.
Another thing I find customers doing is not replacing toners when machine requests them ie at REPLACE TONER, instead they find that just openning and closing lid keeps them going, but these machines hold a complete toner in the drum unit too, so all they are doing is depleting that and when they do finally provide a toner it goes straight into filling up the drum and therefore shortly will display repalce toner again.
Signgirl - your using OEM's so I suspect drum/contacts/eyes what % are t drums at and are they oem too?
Wendy - dont recommend aftermarket/refills all the money you save will be paid to someone like me to come and fix the problems they end up causing.
OKiproblem - ever use aftermarket carts/drum, and what are % of consumables?
SOURCE: Cannon IP1880 Cannot detect Cartridge
press the resume button 5seconds(this disable ink cartridge monitor..
SOURCE: Have an OKI Printing Solution
Found this at Fixyourownprinter.com
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
Worked for me when I had the same error. Hope it helps.
SOURCE: I have a C3530 MFP and it won't print because it
Hi
Thanks for using FixYa. Toner sensor error is related to the agitator inside the toner cartridge, it occasionally falls out of its housing so it does not move the toner sensor which is the white plastic piece that moves up and down on the coloured handle, the toner sensors themselves see this white flag if it doesn’t move then the printer thinks the sensor is broken so toner sensor error is flagged and if the flag moves too quickly the machine thinks the toner is empty. To resolve the issue your printer is facing with please check that toner lock lever is in position and follow the following procedure---
Press the cover release and open the printer’s top cover fully. Make sure the Toner Cartridge in question is correctly positioned and the right hand clip is pushed back. While holding it by its top centre, lift the image drum, complete with its toner cartridge, up and out of the printer. On the Right hand side of the toner look for a sensor patch, make sure this is not dirty. If it is dirty clean it with a soft object such as cotton wool. Now look inside the printer opposite to where the sensor patch would sit. There is a black square with a sensor located inside and check that this is not dirty. Now replace the drum and toner, and close the printer cover. Try to print a test page and it will start printing normally.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
