Question about Reddy Heater-30-55,000 BTU Variable
R55A Reddy heater won't stay running
Heater was in storage brought out filters cleaned and new fuel installed.Heater ran for 1 tank of fuel over 2-3 days and then started to malfunction.Malfunction started with shutting off after running for 4-5 minutes when unplugged and reset would start and run less than 1 minute.That is where we are now,I bought this heater new and it did this same thing shortly after being put into service That is why it was in storage.It has had less than 4 tanks of fuel since it was new out of the box
Posted by David Wade on
5 Related Answers
Anonymous
  • 51 Answers
SOURCE: reddy heater 55000 btu R55A wont stay running
have you cleaned the little sponge filter?
Posted on Jan 09, 2009
Anonymous
  • 92 Answers
SOURCE: pro 110, runs 10 min., blows white smoke ,shuts off
the first thing you need to do is go back to useing K1 kerosene, diesel fuel not only burns dirty but also has a tendency to gel up in cold weather which could be makeing it hard for the heater to draw the proper amount of fuel. To reset the pressure you will need a gage, it should run at about 6-7 psi. you can order a pressure gage from mr. heater online, they are by far the cheapest I have found as they are the actual manufacturer or call 1-800-251-0001
Posted on Feb 05, 2009
jackiaria
Jack Iaria
  • 350 Answers
SOURCE: Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
jack
Posted on Feb 21, 2009
Therinnaiguy
Chandler Ede
  • 1420 Answers
SOURCE: I bought the tb100 30K-55K propane heater I hooked
Make sure that the thermocouple is well into the flame. Check to make sure the other end is secure into the gas valve. Check for any poor connection both gas and electric. If the LP cylinder is icing up, it is a vaporizing problem and the heater is sucking the available gas out of the cylinder faster than it can vaporize. You will need a larger cylinder.
Posted on Nov 26, 2009
SOURCE: heater will run for 15-20min then the flame goes
Sounds like a thermostat problem causing it to run for short periods of time. Check your thermostat first you most likely find the problem there.
Posted on Dec 07, 2010
Cub 1550 with kohler courage. Runs fine and then loses power, runs erratic and starts to backfire. Cleaned carb and fuel pump and ran fine for 30 minutes and then problem started again. When this occurs,...
Replace fuel filter after cleaning tank thouroughly, to clean tank remove fuel line at carb. Drain all fuel then leave line loose until you flush tank with carb. Cleaner then blow out tank with compressed air. Now install new fuel filter and check your fuel can for trash and water better yet just add fresh fuel.
Aug 12, 2017 | Garden
I have a McCulloch Model PM 310 , Gas Chainsaw. How would the spark plug be accessed?....Rich
Storing a chain saw for longer than 30 days requires storage maintenance. Unless the storage instructions are followed, fuel remaining in the carburetor will evaporate, leaving gum-like deposits. This could lead to difficult starting and result in costly repairs. Never store a chain saw for longer than 30 days without performing the following procedures:
Remove the fuel tank cap slowly to release any pressure in tank. Carefullydrain the fuel tank.Start the engine and let it run until the unit stops to remove fuel from carburetor. Allow the engine to cool (approximately 5 minutes).
Using a spark plug wrench, remove the spark plug.
Pour 1 teaspoon of clean 2-cycle oil into the combustion chamber. Pull starter rope slowly several times to coat internal components. Replace spark plug.
Store the unit in a dry place and away from possible sources of ignition such as a furnace, gas hot water heater, gas dryer,etc. When removing the unit from storage, be sure to perform the following procedures:Remove spark plug. Pull starter rope briskly to clear excess oil from combustion chamber.Clean and gap spark plug or install a new spark plug with proper gap.Prepare unit for operation.Fill fuel tank with proper fuel/oil mixture.
This will help. Thanks, please keep updated. please do rate the solution positively .thank you for using fixya
Dec 15, 2009 | McCulloch MC1275 Steam Vacuum
No Power at High RPM
Sounds like a fuel problem, possible stuck needle valve. Did you check for vacuum leaks? How about the fuel itself, did you treat it before storage to prevent gelling and varnish ? If not your entire fuel system may be restricted. Purchase a can of Seafoam...pour in 1/2 of it to a tank of gas, use the other 1/2 on the next tank. Change fuel filter afterwards because any foreign materials will be in the filter from the cleaning process. Third tank normal fill.
Good luck...i hope this helps.
Apr 25, 2009 | 2003 Yamaha V Star 1100 Classic
Clicks but wont fire
make sure the high voltage lead to the sparkplug isn't touching anything metal on its way to the plug. the clicking may be the high voltage discharging to a metal part, not the plug. those wires age during use.
Dec 01, 2007 | Reddy R70ET Utility Heater
Reddy Heater-30-55,000 BTU Variable Logo
678 people viewed this question
Top Reddy Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Fahr Quad
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
