Question about Sony Fd Trinitron Wega Kv-36fs13 36" Crt Television Excellent Condition
Adjust the vertical hold on my sony KV 36fs13
Posted by john gores on
Brandon Murphy
    Sergeant:
  • 214 Answers
Look for a hole in the back of the TV that says vertical hold or it would be in the TV on the PCB. Just look for a small pot.
Posted on Dec 29, 2012
Sony trinitron kv-36fs13 standy by blinks 5 time then stops buts keeps repeating steps
AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. If you wish to get more details about blinking codes to Sony TVs, check this link.
Feb 19, 2013 | Televison & Video
Sony trinitron KV-32HS510 has vertical hold problem
It could just be a resistor or two ,
check for Vert Oscillator Circuit & AGC
Jul 27, 2012 | Sony FD Trinitron WEGA KV-32HS510 32" TV
My sony kv-36fs13 picture is very red. I tried adjusting the hue without success. I am getting the little red light on the front of the tv blinking five times. Any ideas?
open the back cover of your TV (unplug the unit) using a soldering Iron,resolder all the components at the CRT socket .the small square board attached to the tail of picture tube That's it! good luck and please dont forget to rate I need it to keep going...
Mar 08, 2011 | Sony KV-36FS13 TV
How to hook up a Sony Large Screen FD Trinitron WEGA stereo color TV (KV-36FS13) to a aiwa cx-na888
first of all i did fing the sony manual on sony's website http://www.docs.sony.com/release/KV36FS13.PDF
page 32 shows the audio out jacks , run the red and white wires to the inputs on the aiwa (i did not find a manual for the aiwa) if there are no input jacks on the aiwa then you can not connect it.
hope this helps
Thanks
Roety
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Dec 23, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony wega KV-36FS13 standby light blinking 5 times. no pic.
non of the blinks are good but here is yours
\5 times, Diagnosis: White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small.
also not a DIY
Please rate my help++++Thankis for using FIXYA
May 19, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony trinitron picture bowed
YOU MAY A PINCUSHION PROBLEM...SEE A TECH....CUSTOMER CONTROLS WILL NOT CORRECT THIS !
Dec 21, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
How do i adjust the vertical hold on my sony trinitron 36-inch KV-35S66?
take the back cover off there shoulde be one or more little knobs so you can adjust the tv
Feb 25, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
KV-36FS13
Your TV has problem in Tuner section hardware and its not so costly repair. Watching cable trough VCR is alternative solution, which you already have.
Aug 02, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Trinitron Power Surge 5 Blinks
once you have diagnosed the problem, the following link is to all parts for your tv stocked at partstore. they generally have better prices than the dealers and repair shops.
KV-36fs13 parts
you can try the dead-tv kit from fixyourowntv if you have some basic experience with soldering and circuit repair.
http://fixyourowntv.com/orderpage.php
Five blinks means, "IK (AKB)" (white balance). The probable causes listed by Sony are as follows:
1) Video OUT (IC561) is faulty (A board)
2) IC355 is faulty (A board)
3) Screen (G2) is improperly adjusted.
not sure what the 13 blinks are for.
hope this helps,
trin
Nov 19, 2007 | Sony KV-27FV16 TV
Sony Fd Trinitron Wega Kv-36fs13 36" Crt Television Excellent Condition Logo
222 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
