Network connection on Kodak pulse frame not found
Either you are not entering you web key for the wifi correctly or you have not entered the activation code for the frame which can be found when you hold the heath check button on the back of the frame
Posted on Oct 09, 2013
SOURCE: kodak 8" touchborder digital frame user manual
http://wwwuk.kodak.com/global/en/service/publications/index.jhtml?pq-path=1398
Posted on Nov 17, 2009
SOURCE: kodak picture frame will not turn on, has no reset
I had this same issue. I hadn't used my frame in about a year and wanted to turn it on to show photos during the holiday gatherings. When i turned it on it would boot up then shut off. I realized the cord I was using wasn't the original cord and the output voltage was too low to power the frame. Make sure you are using the correct ac/dc cord.
Posted on Jan 03, 2011
SOURCE: Pictures don't fill screen on Kodak M820 Digital picture frame
Because a digital photo frame's display ratio doesn't always match the original picture ratio, some pictures cannot be displayed in a satisfactory manner. For example they may be rendered too small, with black borders, or they may be automatically zoomed-in and randomly cropped.
With a computer, this issue can be resolved by using generic photo editing software like Adobe Photoshop, or specialized software like DPF Manager, Digital Frame Master or FrameSize, to properly crop the pictures before transferring them to the digital frame. Without a computer, there is no other option but manually deleting incompatible pictures by using frame's built-in functions.
Also, check the settings and try the "Fit to Screen" but, with some models the width of each landscape image is stretched to
achieve an aspect ratio of 16:9, which results in noticeable distortion.
Posted on Jan 04, 2010
SOURCE: My kodak easyshare sv811 digital picture frames music not playing
Most files you download say from I tunes are "protected" files. They will not transfer. You have to convert it to an MP3 file. I found a free converter on the web that will convert your protected files to MP3 file then you can download it to your photo frame. i just bought one today and it took me ALL DAY to figure this out. What a PAIN! good luck!
Posted on Dec 22, 2008
SOURCE: Kodak EasyShare software won't connect to digital photo frame
I had some problems with wireless connectivity with the Ex1011. It turned out to be the connection was breaking when I used WPA security. When I went to WEP it worked fine. My suspicion is that the router was changing the Key over time and the frame wasn't following it. So it would work for a while then stop. But also had trouble even seeing it at times. Anyway, worth a shot. You might try turning off security on the router altogether to see if it makes a difference. Good luck.
Posted on Dec 20, 2008
Aug 17, 2017 | Kodak Photography
Mar 03, 2015 | Kodak ESP 7250 All-in-One Printer
Nov 16, 2013 | Kodak W730 PULSE Digital Frame
Oct 15, 2013 | Kodak Cameras
Mar 31, 2010 | Kodak Office Equipment & Supplies
Sep 18, 2009 | Kodak Cameras
Jan 11, 2009 | Kodak EasyShare EX1011 Digital Picture...
Dec 05, 2008 | Kodak EasyShare EX1011 Digital Picture...
Dec 04, 2008 | Office Equipment & Supplies
2,754 people viewed this question
