Question about RCA F36649 36" TV
RCA F36649 will be fine for about 5-10 minutes after turning on, then the picture will slowly start to become distorted until it is just a bunch of lines. Please help!
Posted by Jerry Anderson on
Brandon Murphy
    Sergeant:
  • 214 Answers
Bad capacitors it seems. Very easy fix.
Posted on Dec 29, 2012
2 Related Answers
pgh_pa_guy
  • 2992 Answers
SOURCE: Picture Problem
This is a problem (one of several) caused by poor solder connections on the circuit board. RCA uses the metal shield can surrounding the tuner circuitry (the area where the cable connector is located) to provide several ground connections. Many of these connections go bad (cracks form) and the missing ground connections cause the "picture shrinking" you see. Other problems are loss of tuning, set that intermittently turns off or on by itself, set that won't turn on at all, and even more.
The repair involves removing the circuit board and flipping it over so you can remove a metal cover on the bottom, repairing the several (many) affected connections, and then reassembling. This is a relatively easy repair for someone with soldering experience and the right tools (both a high-heat soldering gun and a low-heat iron are needed). But because of the fragile circuit traces in the repair area it is possible to do more harm than good if you don't know what you're doing.
RCA produced a service bulletin several years back detailing the areas to be repaired (although they still refused to admit they just hadn't soldered the places adequately to begin with). I'm not home now so I can't check my files but I'll see if I can find a link and add a comment later. When I was in the service business we charged around $60 for the repair. You might want to get an estimate from a shop (they should already be familiar with this trouble). Or if you're looking for a reason to buy a new set, try the repair yourself. If you're successful you've saved yourself the money. If not, it wasn't working anyway!
Posted on Feb 02, 2009
SOURCE: When I turn my RCA F32672SB on the picture is
after 4 or 5 yrs EHT ( transformer that supplies voltage to CRT TUBE - TV TUBE ) becomes weak - then 1 of the indication is ...display becomes blur .......so solution is EHT ( also called as flyback transformer ) should be replaced....... {{ few details about EHT---- its size will be around 3inch X 2inch X 2inch ---it will have 2 or 3 knobs to adjust focus , brightness ------ at bottom around 10 pins will be there ------- from EHT 1 thick red colour cable goes to CRT TUBE --------- on EHT its part number will be there }} -------- so if user is a technical person having idea about components ( resistors, transistors, diodes, etc ) , having tools like multimeter ( to check components) , soldering iron, soldering lead, flux, desoldering wig ( for removing components), etc also little experience in servicing field( compulsory) ----------------- then user can remove EHT from main board ---- take to electronic shop ----- buy same type EHT --------- fix to mainboard ( knobs on EHT should be adjusted according to picture --- after switching TV --- this adjustment is very important ) ----------iam from bangalore (09986222774, [email protected]) ----- here EHT's price will be around Rs 250 ( US $ 6 ) & for my customers (in bangalore) i will take another Rs 500 (US $ 11) as service charge......i don't have any idea about EHT ' s price & service charge in your place.........since it is very risky job i suggest to contact TV service engineer ------- because they are highly experienced & can fix this component very easily. ------------ [[ sometimes along with EHT another component called transistor ( big in size - situated close to EHT - it will have 3pins - its size will be 1inch X 1/2 inch X 1/2 cm --approximately ---- black in colour ----- fixed to aluminium metal ) --- will also gets deffective --- so this component also should be checked ]] ---- in your case this transistor is good ... because when this component gets deffective then TV won't get '' ON '' .............so in your case only EHT ( same type ) should be replaced.........100% it works normally
Posted on May 22, 2011
The sound is al static
Make sure if you have a set top box (cable box) that the volume is turned up in that.
Apr 15, 2010 | RCA F36649 36" TV
Samsung DLP 56" tv,distorted picture
if you say that your picture gets distorted you mean like it moves to a side? do you see a black middle block?
if it's a yes?
so its probably the light engine. you need to change it!
try this link.. http://www.discount-merchant.com/1069179-HL-N5067W-p/1069179.htm
the price is more or less depends on your TV model... $279.00
Feb 02, 2010 | Samsung DLP HL-P5663W 56" TV
Picture/color distorted
If the picture appears as 3D thats a simple and inexspensive repair. You can get the repair kit for your RCA Called "The ITC222 and ITC222A convergence option missing repair Kit" from www.tvrepairworld.com the kit contains the parts and the CD with detailed instructions.
Dec 25, 2009 | RCA D52W19 52" Rear Projection Television
Hi I have a sony KDP-57XBR2 television set and the
I had the same problem in blue. I took the right front speaker cover off (pops off) and the access panel on the right side 2 - 4 screws. In the upper right corner is a black plastic box with 2 rows of 3 adjustment screws. All I did was turn one of the "screen" screws (not the "focus" screws). Hope this helps. May only be a temporary fix, but good luck...
Aug 19, 2009 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Sony KV-32XB25 Distorted Picture
In most of the case, the problem is a defective LCD panel, if is it, there is not worth to fix.
Aug 02, 2017 | Sony KV-32XBR250 TV
Visual and power problem
Bad high voltage transformer. Most original transformers are not made anymore by RCA.
Mar 04, 2008 | RCA P52926 52" Rear Projection Television
Buzzing noise with no picture or sound.
The power supply is telling you that it has a short. I think you have a bad high voltage transformer in the horizontal deflection circuit. I've repaired several RCA's with this very same problem. The newer RCA's are vert prone to high voltage transformer failure ! Stargazer
Aug 20, 2007 | RCA F36649 36" TV
High pitch ringing noise and picture distortion
Sounds like the capacitor that goes bad just before the hIgh Voltage transformer goues bad. If i were you I would call an authorized RCA repair Shope and see if this is going to cause more damage to your set in the future.
Aug 25, 2006 | RCA HD52W59 HDTV Projection Television
RCA F36649 36" TV Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
