I want cusinart blender cb-600pc(TX) blade and gasket where we can get ? i have seen in cusinart online but it will showing cbt-600 it will fix to cb-600pc or not?
Hi Paul,
There is a collar on the base of the jar that screws onto the jar. You will need to unscrew the collar and fit a replacement blade. make sure the seal is replaced with the blade and the collar is screwed back securely.
See this link for the parts of the blender. CUISINART CANADA SmartPower Premier 600 Watt Blender CBT 500C
Also see the product description for the blade.
https://www.youtube.com/watch?v=rdBxUAsT_TQ
On page 4 of the manual is the instructions for assembly of the jar. With the jar upside down, lay the gasket on the threaded area, insert the blade/plate, and screw on the base. Nothing to it.
Sounds like the teeth are stripped underneath the blade. Make sure it's put together correctly before you do anything else. Download Cuisinart CBT 500 Manual
Hey, I know this is an old thread but just had the same problem and solved it. With the blender container upside down, place the gasket on the jar hole, put the blade through the hole on top of the gasket, then screw the plastic base on top of that.
The way I had done it before was to pop the blade into the bottom of the plastic base first then screw it onto the gasket and jar but it goes on the gasket, not under the bottom of the base. Hope that helps anyone else in the future.
Also just read the manual instructions like I didn't, clear as day right there but I never bothered to read them ha
You have a Sam's Club variant of the model:
The blender parts are the same for that model as for the CBT-500 - food processor parts are the same as for the BFP-703
