IBM Lenovo ThinkPad X40 Notebook Logo
Posted on Dec 29, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
White spot on my laptop screen Hi..i got white spots on my laptop screen...almost right side...please tell me how to solve this problem...
Tech Hamza
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 28, 2023
Tech Hamza
Contributor
Level 1:
Answers
Questions
0
Helped
141
Points
This guide might help you fix white spot or dot issue: https://pcglance.com/how-to-fix-white-spot-on-laptop-screen/
max carson
Level 3:
  • IBM Master 7,627 Answers
  • Posted on Dec 29, 2012
max carson
IBM Master
Level 3:
Answers
7627
Questions
Helped
1015098
Points
21773
Sounds like the monitor is going.
1helpful
White spots on screen on dell m209x projector how do i fix ?
1,white spots appeared on screen,means the DMD is broken,you need a new DMD. USD200
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel, motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: [email protected]
Skype: lampdeng.com
YM: [email protected]
http://facebook.com/lampdeng
http://www.lampdeng.com
1helpful
2answers
I have a NEC projector in my class but projects white spots on the screen which are multiplying day by day. Has anybody solved this problem ???
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD, motherboard, powersupply ... with high quality and competitive price.
Jerry China
Skype: lampdeng.com
I have sanyo projector model PDG-DSU20E. Few white spots appeared on the right side of the screen. Gradually the spots has filled the right side about 1 feet is width till bottom of the screen. Now few...
2,the projector running off after only a few minutes,means the Inductor (Sensing element),near the Color Wheel. Use a cotton swab moistened with alcohol to wipe the Inductor.
Have a good day!
Jerry China
Skype: lampdeng.com
White on one side of screen with black spots and colored lines
You can use the following website to try and fix some of these pixels that are stuck on the wrong colors:
http://udpix.free.fr/
However, it may just be a defective screen. You may need to have it replaced under warranty (and this most definitely will be covered)
1helpful
Lenovo Y410 white screen
All that's left is the Video Cable, and LCD screen, Aberger.
Video Cable connections are tight? LCD screen side, screen Inverter, and motherboard side?
Then a continuity check with a multimeter set to OHMs, for each wire in the cable, or take to a 'Mom and Pop' computer store, and have the tech check it, or replace.
Video Cable checks out, connections check out, the LCD screen is the problem.
My money is on a bad LCD screen, JMHO.
Regards,
joecoolvette
1helpful
Increase color depth for strange colors on your display.
If that doesn't work you probably have dead spots on your screen that no longer work. This means that your LCD assembly is no longer functioning and you will need to replace it.
White spots..
Dell Latitude D620 Laptop (Latitude-C620) PC Notebook
take alook there and see if you can tell what to do.
Then I often find that is good to click on START-control panel once there click on display. There you can control your sisplaay and hopefully get rid of the white spots.
all the best
kollagunn
2answers
White spot
The spot may be where something has pushed against the screen to fix this problem you will need to buy a new screen sheet.
3helpful
2answers
I having white spots poping up all over my screen
check out for the convergence ic on the convergence board that ic must be faulty and it needs replacements.there are two such stk ic that both needs to be replaced as replacing 1 ic will not solve the problem.
Top IBM Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
